"compilation error: 'class BlynkWifi' has no member named 'notify'"
• Hardware model: Node Mcu ESP8266 with WiFi
#define BLYNK_TEMPLATE_ID “TMPL6qM2TAJLq”
#define BLYNK_TEMPLATE_NAME “IOT Plant Monitoring”
#define BLYNK_AUTH_TOKEN “------”
#include <DHT.h>
#include <OneWire.h>
#define ONE_WIRE_BUS 18 //D3
char ssid = “MiFi-32BC”; //WiFi SSID
char pass = “1234567890”; //WiFi Password
#define sensorPin 17 //D4
int sensorState = 0;
int lastState = 0;
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
Serial.println(“Failed to read from DHT sensor!”);
return;
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature
pinMode(sensorPin, INPUT);
dht.begin();
sensors.begin();
int sensor=0;
void sendTemps()
sensor=analogRead(A0);
float temp = sensors.getTempCByIndex(0);
Serial.println(temp);
Serial.println(sensor);
Blynk.virtualWrite(V1, temp);
Blynk.virtualWrite(V2,sensor);
sendTemps();
sensorState = digitalRead(sensorPin);
Serial.println(sensorState);
if (sensorState == 1 && lastState == 0) {
Serial.println(“needs water, send notification”);
Blynk.notify(“Water your plants”);
lastState = 1;
//send notification
else if (sensorState == 1 && lastState == 1) {
  //do nothing, has not been watered yet
Serial.println("has not been watered yet");
else {
  //st
  Serial.println("does not need water");
  lastState = 0;
delay(100);
Please help me. Cannot solve this problem for long.
@Jerry Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Post removed by moderator as it gives incorrect advice
You’re getting this compilation error because Blynk.notify() is a Legacy command which is no longer supported in Blynk IoT.
Blynk IoT handles notifications as part of the Blynk.logEvent command. More information in the documentation and here…
In addition, your code has quite a few other problems…
  1. you should be using BlynkTimer instead of SimpleTimer.
  2. you have two Serial.begin() commands in your void setup.
  3. your void loop is very cluttered, and you’re using blocking delay() commands to regulate the frequency of your sensor readings. Instead, your void loop should just have the Blynk.run() and timer.run() commands in it, and the other code should be in a separate function which is called using a BlynkTimer. Read this for more information…
