BOARD : ARDUINO UNO
SHIELD : HC 05 BLUETOOTH MODULE
This is my first code , which is meant to read the digital pins of arduino , say pin11 and 10 and write the value to pin13 . i interfaced the bluetooth module and saw the program working fine and dislayed the necessary string like “over voltage” or " normal " in lcd widget .
int relay=12;
int inpin_ru=11;
int inpin_ro=10;
int val_ru=0;
int val_ro=0;
SoftwareSerial SwSerial(2, 3); // RX, TX
char auth[] = "523d3815fd454238899b9e9ce5aa1dff";
SoftwareSerial SerialBLE(2, 3); // RX, TX
WidgetTerminal terminal(V0);
void myTimerEvent()
val_ru = digitalRead(inpin_ru);
val_ro = digitalRead(inpin_ro);
if (val_ru == 1)
Blynk.virtualWrite(V0,"R-UNDER VOLTAGE");
if (val_ro == 1)
Blynk.virtualWrite(V0,"R-OVER VOLTAGE");
if (val_ru == 0 && val_ro == 0)
Blynk.virtualWrite(V0,"NORMAL");
pinMode(relay, OUTPUT);
pinMode(inpin_ru, INPUT);
pinMode(inpin_ro, INPUT);
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
timer.setInterval(1000L,myTimerEvent);
digitalWrite(relay,val_ru||val_ro);
below is my second code to monitor current using ACS712 30A current sensor and the program worked fine when it ran separately in the arduino and displayed the current in super chart .
const int sensorIn = A0;
int mVperAmp = 66; // use 100 for 20A Module and 66 for 30A Module
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
void getACS712()
Voltage = getVPP();
VRMS = (Voltage/2.0) *0.707;
AmpsRMS = (VRMS * 1000)/mVperAmp;
Serial.print(AmpsRMS);
Serial.println(" Amps RMS");
Blynk.virtualWrite(V1 , String(AmpsRMS, 3));
float getVPP()
float result;
int readValue; //value read from the sensor
int maxValue = 0; // store max value here
int minValue = 1024; // store min value here
uint32_t start_time = millis();
while((millis()-start_time) < 3000) //sample for 1 Sec
readValue = analogRead(sensorIn);
// see if you have a new maxValue
if (readValue > maxValue)
/*record the maximum sensor value*/
maxValue = readValue;
if (readValue < minValue)
minValue = readValue;
// Subtract min from max
result = ((maxValue - minValue) * 5.0)/1024.0;
return result;
timer.setInterval(3000L, getACS712);
Next when i tried to combine both programs into one , what happened is only the first program (sensing digital pins and writing in lcd) got worked , current part was idle . i dont know if its an issue with the timer or whatever ? below is the combined code .
int relay=12;
int inpin_ru=11;
int inpin_ro=10;
int val_ru=0;
int val_ro=0;
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
void myTimerEvent()
if (val_ru == 1)
if (val_ro == 1)
void getACS712()
Voltage = getVPP();
float getVPP()
float result;
return result;
please help ! i’m a noobie
