if one is HIGH and the other is LOW?
write pin 12 HIGH or LOW? Which ONE!
clear your loop first
Pin 12 goes HIGH ! I’m not bothered about logic !
Thanks anyways sir .
Second code is creating all the trouble
No problem. Good Luck.
Blynk only suggests to keep away the codes regarding the retrieval of some data from these void loop .
That code inside void loop controls the switching of relay like normally ! It doesn’t send us any data
@PeteKnight sir , is there any possibility of bringing Blynktimer timer1 and Blynktimer timer 2 and putting timer1.run and timer2.run ?
the dog will be angry.
but do as you like
that makes no sense to read and write every milliseconds.
Don’t do that. You can have up to 16 separate timer instanced for each timer object, so it’s not necessary.
It’s already been pointed out that these two software serials, on the same pins, won’t work.
The advice about cleaning up your void loop is very good advice, take heed of it!
Missed this the first time around:
uint32_t start_time = millis();
while((millis()-start_time) < 3000)
Let us know what you get in serial monitor too.
