Dear all, for those of you who still uses old Blynk host - please switch to new one blynk-cloud.com ASAP.
How or where does one do that? I don’t find either server name in the application code, or by grepping through the library.
In case you are using latest apps and libraries everything is fine for you.
Great! I am - thanks.
Yes, but how to update remote IoT devices wich are at our clients?
Well this sucks. How do we update remote devices?
How do we update the blynk library? Mine didn’t have an update button?
Never mind, I updated it
How did you update?
Can’t talk to devices.
I wasn’t able to update remote devices. You will have to go to there location. And hopefully you still have the file to program each device.
I sure hope this doesn’t happen again.
it will 100% happen again.
if it wasn’t free, you could expect more, but redundancy costs money:
Re flashed my particle. Still not working.
Do I need to get a new auth token and put it in my device?
Got my iOS app logged in now!
i had to change my DNS server to 8.8.8.8 in my router to get my Blynk stuff back again…
I changed my DNS to 8.8.8.8 GOOGLE DNS server I think and ping blynk-cloud.com and got 45.55.130.102
and with my ISP DNS I got the same. So I don’ think that my problem. Thanks
Any more thoughts what my problem is?
Norm
I just went in and looked at the serial monitor and my devices is saying " connecting to cloud.blynk.cc:8442 "
ever 5 sec that’s wrong right!
Norm
While making a put request instead of using -http://cloud.blynk.cc:8080/auth_token/pin/pin
what do i have to use?
this - http://blynk-cloud.com/auth token/pin/pin ?
That is wrong, mine is:
[1267] Connected to WiFi
[1267] My IP: 192.168.0.179
[1267] Blynk v0.3.5-beta
[5001] Connecting to blynk-cloud.com:8442
[5181] Ready (ping: 1ms).
http://blynk-cloud.com:8080/auth/pin/pin
However I don’t think 8080 is absolutely required… worked for me without (which I believe would be port 80).
In other words, mine is: http://blynk-cloud.com:8080/myAuth/pin/V16 and it cranks out: ["HVAC ON since 9:02PM on 5/25"]
and what we should put in the PIN jus tleave it like that and add token ?
Authentication token is unique for every project. You need to put that token there and the pin which you want to control.
