I am planning to make a project which involves an ESP32 controlling some 12V Motors and an RGB Led Strip. The Led Strip needs to be dimmable(PWM). In the past I have used the BD711 and the TIP31. They work but since the ESP outputs 3.3V the Transistor is not fully turned on. I was searching online and found this MOSFET. The IRF3708. I was thinking if I could use this instead so that I can get the maximum output from the MOSFET. Do you think this is a great choice or is there something better?
Don’t forget that if you use Arduino code that is meant for 255 PWM levels then you’ll never get full brightness with an ESP8266/ESP-32 because they use 1023 PWM levels.
