BLYNK
Change Manual and automatic mode in blynk
Hello Blynk community.
i have a project for home automation which uses LDR, Dht11, Nodemcu and a couple of relays.
the idea is to have a manual and automatic mode. when in automatic mode, the relay automatically activates when the LDR value is lower than 800.
the automatic part works well but the manual section doesn’t seem to work, the Lights do not switch on when the button is pressed in the Blynk…
#include "DHT.h"
#define DHTPIN              D1
#define DHTTYPE DHT11
#define relaypin D2
#define LED2     D3
#define LDR_PIN             A0
const int maxLight = 1000;
const int minLight = 800;
int   ldrVal;
DHT dht(DHTPIN, DHTTYPE);
int selectMode;
int Switch;
char auth[] = "*****";
char ssid[] = "*****";
char pass[] = "*****";
float t;                                   // Declare the variables
float h;
  pinMode(LED2, OUTPUT);
  pinMode(relaypin, OUTPUT);
  timer.setInterval(1000L, Mode);
  timer.setInterval(1000L, sensorDataSend);
  dht.begin();
BLYNK_WRITE(V5)
  Switch = param.asInt();
  Lamp;
void Lamp()
  if (Switch == 1)
  digitalWrite(relaypin, HIGH);
  digitalWrite(relaypin, LOW);
BLYNK_WRITE(V4)
  selectMode = param.asInt();
  Mode;
void Mode()
  if (selectMode == 1) //If button MANUAL on app
  digitalWrite(LED2, HIGH);
   Serial.println("Manual");
   Lamp;
    digitalWrite(LED2, LOW);
    Serial.println("Automatic");
    sensorDataSend;
void sensorDataSend()
ldrVal = analogRead(LDR_PIN);
  float h = dht.readHumidity();
  if (selectMode != 1)
  if (ldrVal < minLight) {
    Blynk.virtualWrite(V3, "DARK");
  else {
    Blynk.virtualWrite(V3, "LIGHT");
  Serial.print(F("Humidity: "));
  Serial.print(h);
  Serial.print(F("%  Temperature: "));
  Serial.print(t);
  Serial.println(F("°C "));
  Serial.println( ldrVal);
  Blynk.virtualWrite(V0, t);
  Blynk.virtualWrite(V1, h);
  Blynk.virtualWrite(V2, ldrVal);
A post was merged into an existing topic: Automatic and Manual mode In Blynk Project
