Bedan
September 10, 2020, 12:51pm
1
Hey guys, i am trying to make a home automation project with an LDR, DHT11, nodemcu and Blynk.
The automatic part of the project works okay… the relay turns on automatically when the value of the LDR is less than 800.
I have tried to use a manual button to turn on the relay but the relay only flashes on and off
Please Help…
I am a total noob.
#include "DHT.h"
#define DHTPIN D1
#define DHTTYPE DHT11
#define relaypin D2
#define LED2 D3
#define LDR_PIN A0
const int maxLight = 1000;
const int minLight = 800;
int ldrVal;
DHT dht(DHTPIN, DHTTYPE);
int selectMode;
char auth[] = "*****";
char ssid[] = "*****";
char pass[] = "*****";
float t; // Declare the variables
float h;
pinMode(LED2, OUTPUT);
pinMode(relaypin, OUTPUT);
timer.setInterval(2000L, Mode);
timer.setInterval(2000L, sensorDataSend);
dht.begin();
BLYNK_WRITE(V4)
selectMode = param.asInt();
Mode;
void Mode()
if (selectMode == 1) //If button MANUAL on app
digitalWrite(LED2, HIGH);
Serial.println("Manual");
digitalWrite(relaypin, HIGH);
Serial.println("Bulb ON");
digitalWrite(LED2, LOW);
Serial.println("Automatic");
sensorDataSend;
void sensorDataSend()
ldrVal = analogRead(LDR_PIN);
float h = dht.readHumidity();
if (ldrVal < minLight) {
Blynk.virtualWrite(V3, "DARK");
else {
digitalWrite(relaypin, LOW);
Blynk.virtualWrite(V3, "LIGHT");
Serial.print(F("Humidity: "));
Serial.print(h);
Serial.print(F("% Temperature: "));
Serial.print(t);
Serial.println(F("°C "));
Serial.println( ldrVal);
Blynk.virtualWrite(V0, t);
Blynk.virtualWrite(V1, h);
Blynk.virtualWrite(V2, ldrVal);
How is your switch widget configured in the app?
Push or Switch mode?
I suspect this is due to the fact that you have the two timers checking each function. When in manual mode it turns On the relay, but then checks the value of the LDR and if not high enough it turns the relay off. You need to add in a check in your sensorDataSend() function that checks if it is in manual mode.
You would also want to get rid of the else statement in the mode() function as this will override the LDR function. Or move it all to the BLYNK_WRITE() function.
For Example:
dht.begin();
BLYNK_WRITE(V4)
t = dht.readTemperature();
if (selectMode != 1)
else {
Serial.print(h);
Serial.print(t);
Bedan
September 10, 2020, 5:09pm
6
Thanks it works …
I would like to make the button switch on and off while in manual instead of just moving to the “void sensorDataSend()” when off
I’d use two buttons. One for auto/manual, and one for On/Off in Manual Mode
Bedan
September 10, 2020, 7:29pm
9
Hello Blynk community.
i have a project for home automation which uses LDR, Dht11, Nodemcu and a couple of relays.
the idea is to have a manual and automatic mode. when in automatic mode, the relay automatically activates when the LDR value is lower than 800.
the automatic part works well but the manual section doesn’t seem to work, the Lights do not switch on when the button is pressed in the Blynk…
#include "DHT.h"
#define DHTPIN D1
#define relaypin D2
#define LED2 D3
#define LDR_PIN A0
int ldrVal;
int selectMode;
int Switch;
float h;
timer.setInterval(1000L, Mode);
timer.setInterval(1000L, sensorDataSend);
dht.begin();
BLYNK_WRITE(V5)
Switch = param.asInt();
Lamp;
void Lamp()
if (Switch == 1)
BLYNK_WRITE(V4)
Mode;
void Mode()
Lamp;
sensorDataSend;
else {
Serial.print(h);
Serial.print(t);
Please don’t keep creating new topics about the same subject.
I’ve merged your new topic into this one.
BLYNK_WRITE(V4)
Blynk.syncVirtual(V5);
BLYNK_WRITE(V5)
manualMode = param.asInt();
if (manualMode == 1)
Serial.println("Bulb OFF");
Blynk.virtualWrite(V5, HIGH);
else {
Blynk.virtualWrite(V5, LOW);
Serial.print(h);
Serial.print(t);
