Change auth, ssid and pass from BLYNK terminal for NANO+ESP-01 project
I needed in the project (NANO+ESP-01 serial hardware connection) to have possibility to change the SSID and pass without a change in the program. I prepared this part of the program. It works :slight_smile:
New Wifi data are input from BLYNK terminal and stored in the EEPROM.
After reset login to wifi depends on the port 8 - HIGH = Default ssid and pass, LOW = new setup ssid and pass.
The program also has the ability to change the autch.
  set new wifi
  V15 - terminal
  V17 - button SETUP - setup new wifi data
  V18 - button -View default wifi data
  V19 - button - View new setup wifi data
  V20 - button OK - save to eeprom new setup wifi data
  v21 - button RED - read from eeprom setup wifi data (test only)
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"; //valid auth
char ssid[] = "aaaaaaaa";   // default ssid
char pass[] = "bbbbbbbbbbbb"; // default pass
char auth[] = "6a9442c5d30d4e83a7d5c2xxxxxxxxx"; //valid auth
char ssid[] = "aaa";
char pass[] = "12345678";
char t_auth[] = "77778888999911112222333344445555"; // declare same 32 char
char t_ssid[] = "same AP name 123456789"; // declare
char t_pass[] = "same AP password 123456789"; // declare
#include <ESP8266_Lib.h>
#include <EEPROM.h>
#define EspSerial Serial // Set ESP8266 Serial object
ESP8266 wifi(&EspSerial);
WidgetTerminal terminal(V15);
const int SW_pin = 8; //Working mode switch. HIGH = default WiFi. LOW = castom WiFi
String      y_ssid = "";
String      y_pass = "";
String      y_auth = "";
int wpis = 0;
int dl_i = 0;
int dl_j = 0;
int dl_k = 0;
BLYNK_WRITE(V15)
  String  coscos = param.asStr(); // string from terminal
  switch (wpis)
    case 1:
      y_auth = coscos;  //from terminal
      dl_i = y_auth.length() + 1;  //change string to char[]
      y_auth.toCharArray(t_auth, dl_i); //change string to char[]
      break;
    case 2:
      y_ssid = coscos;
      dl_j = y_ssid.length() + 1;
      y_ssid.toCharArray(t_ssid, dl_j);
      break;
    case 3:
      y_pass = coscos;
      dl_k = y_pass.length() + 1;
      y_pass.toCharArray(t_pass, dl_k);
      break;
    default: ;
BLYNK_WRITE(V17) //button SETUP
  String coscos;
  int klawin = param.asInt(); //klaw SETUP
  if (klawin == 1) {
    wpis = wpis + 1;
    if ((wpis > 4) || (wpis < 1)) {
      wpis = 1;
 switch (wpis)
    case 1:
      terminal.println("print your auth: ");
      terminal.flush();
      break;
    case 2:
      terminal.println("print your ssid: ");
      terminal.flush();
      break;
    case 3:
      terminal.println("print your pass: ");
      terminal.flush();
       break;
    case 4:
      terminal.print("your auth: ");
      terminal.println(t_auth);
      terminal.print("your ssid: ");
      terminal.println(t_ssid);
      terminal.print("your pass: ");
      terminal.println(t_pass);
      terminal.println("data wifi OK ?");
      terminal.flush();
      break;
    default: ;
BLYNK_WRITE(V18)
  int klawplus = param.asInt();
  if (klawplus == 1) {
    terminal.println("**** DEF ****");
    terminal.print("auth: ");
    terminal.println(auth);
    terminal.print("ssid: ");
    terminal.println(ssid);
    terminal.print("pass: ");
    terminal.println(pass);
    terminal.println("********");
    terminal.flush();
BLYNK_WRITE(V19)
  int klawminus = param.asInt();
  if (klawminus == 1) {
    terminal.println("**** SET ****");
    terminal.print("your_auth: ");
    terminal.print("your_ssid: ");
    terminal.print("your_pass: ");
    terminal.flush();
BLYNK_WRITE(V20) //button OK
  int klawok = param.asInt();
  if (klawok == 1) {
    int eeAddr = 0;
    EEPROM.put(eeAddr, auth); //................................auth not change
    eeAddr = 50;
    EEPROM.put(eeAddr, t_ssid);
    eeAddr = 100;
    EEPROM.put(eeAddr, t_pass);
    terminal.println("save new WiFi data");
    terminal.flush();
BLYNK_WRITE(V21) // button READ for test only
  int  klawread = param.asInt();
  if (klawread == 1) {
    int eeAddr = 0;
    EEPROM.get(eeAddr, t_auth);
    eeAddr = 50;
    EEPROM.get(eeAddr, t_ssid);
    eeAddr = 100;
    EEPROM.get(eeAddr, t_pass);
    terminal.print("your data from ee ");
    terminal.flush();
void wyborwifi() // choice wifi setup data after reset - SW_pin = HIGH > default wifi, LOW > new setup wifi
  pinMode(SW_pin, INPUT_PULLUP);
  int m = digitalRead(SW_pin);
  if (m == 0) {
    int eeAddr = 0;
    eeAddr = 50;
    eeAddr = 100;
    Blynk.begin(t_auth, wifi, t_ssid, t_pass);
//+++++++++++++++++++++++++++++++++++++++++++++++++++   setup
  Serial.begin(115200);  // Set console baud rate
  EspSerial.begin(115200);  // Set ESP8266 baud rate
  wyborwifi();
  Serial.println("Arduino.cc 1.6.9"); //  Arduino.org  doesn't have  EEPROM.get i EEPROM.put functions
@krzyspx any chance you could knock up a video or at least some photos?
It might persuade me to dig out my old school ESP01’s.
I’m guessing you can only change access details if you are still located “at your last location”. What I mean by this is if you are doing it with Blynk you need to be connected to be able to make a new connection i.e. you couldn’t just roam the high street connecting to different AP’s / Hotspots.
This feature allows you to log project to a previously unknown wifi (eg in the location of a client), without changing software. For the configuration I use my phone with the personal hotspot feature (mobile hotspot). In the program I put default parameters of hotspot on my phone . In customer location I change ssid and pass use my hotspot to users data (the customer can do this yourself by setting your phone to the default SSID and pass hotspot data).
Of course, very neat.
But i have a question, if your customer get your product, at the first time, how can they connect the Esp to wifi with your default SSID and Password?
It’s in the manual, probably :slight_smile:
I set in the program as SSID and PASS any value, for example, AAA and BBB. Client on your phone, set it as the parameters for mobile HOTSPOT. The module connects to the Internet via mobiles Hotspot and the client can put own network parameters to the program. After changing the status of the port 8 to LOW and reset program will log on to the network client.
that’s great idea…
Blynk has also Wi-Fi wizard for business. We call it Provisioning. In few clicks you can connect your device with your network from the app.
In the bottom of http://www.blynk.io/business/ you can find few screenshots.
This means that I lost a whole week to prepare and test the login procedure.
What a pity :angry:
The work you did will be invaluable to many.
:slight_smile:
thank you Costas
@krzyspx see your great work in action with a Wio Link (CONFIG button)
Don’t worry about the token, I have changed it on my device :slight_smile:
It’s cool, that application works for ESP also. Is something had to change in the code e.g. writing to the EEPROM?
Good idea with RST button.
No changes required for EEPROM.
I switched to EEPROM by default and Smartphone AP with pin 0 HIGH (not LOW).
So on a Wio Link it is, press the RESET button and then within a fraction of a second press the CONFIG button to ensure it boots to AP. You can’t hold pin 0 down and do a reset or you go into flashing mode.
@krzyspx could I please ask you to provide a sketch extract for us to attach to another button (in Switch mode) that would set the next boot up mode i.e. without the use of a physical button, into Smartphone AP connection or EEPROM connection.
So a flag would be set in the Blynk project to EEPROM for connection type 1 or 2 and if the physical button is not pressed it takes the EEPROM flag to determine the connection type.
See initial extract below, just needs the EEPROM flag write and read on bootup.
String nextbootstring;
BLYNK_WRITE(V14) // next boot, EEPROM flag to have 2 values,
                 // 0 normal boot based on physical button state of HIGH or LOW
                 // 1 boot from EEPROM credentials
  int nextboot = param.asInt(); // ON EEPROM, OFF AP CREDENTIALS
  if (nextboot == 1) {  // boot from EEPROM credentials
    nextbootstring = "ESP will boot from EEPROM credentials next time.";
    // code here, set an EEPROM flag to 1, read at bootup if physical button is not pressed
  else{   // boot from AP credentials
    nextbootstring = "ESP will boot from AP credentials next time.";
    // code here, if EEPROM flag is 1, set to 0
  terminal.println(nextbootstring);
  terminal.flush();
Ok I have made the required changes and it all seems fine.
So now wyborwifi() looks like this:
void wyborwifi() // Select WiFI boot up mode
  pinMode(PIN_CONFIG, INPUT_PULLUP);  // was pin 8
  int m = digitalRead(PIN_CONFIG);    // was pin 8
  EEPROM.begin(4); // read in first byte at address 0
  int eeAddr = 0;
  bootflag = EEPROM.read(eeAddr);// read EEPROM flag for boot mode
  delay(100);
  if ((m == 1) && (bootflag != 1)){ // if pin is HIGH (default) use Smartphone AP credentials, else use EEPROM credentials
    smartphoneconnect();   // use Smartphone AP credentials
    eepromconnect();       // use EEPROM credentials
And the button code is:
int bootflag; // 0 normal Smartphone AP boot, 1 EEPROM credentials boot
    bootflag = 1;
    int eeAddr = 0;
    EEPROM.write(eeAddr, bootflag);
    EEPROM.commit();
    if(bootflag == 1){  // only write value to EEPROM if flag is currently 1
      bootflag = 0;
      int eeAddr = 0;
      EEPROM.commit();
  terminal.flush();
Tested and works ok.
Edit: @krzyspx I have moved all your starting addresses from 0 to 1 and now the sketch with read and write is fine, rather than get and put.
It’s a great solution - replace the physical button on the record byte EEPROM
First - the customer does not have to open the case to change the wifi
second - it is able to support more than two networks stored in the program memory or EEPROM
Thank you very much Costas for the creative development of the project
Can you spot the bugs in my code as it is not booting from EEPROM credentials?
I have tried changing bootflag from int to String but still no joy.
