Hi friends. I want to store connected IP in local server but cannot be worked. I changed the allow.store.ip=true in the server.properties but nothing. server version is 0.39.0
What IP do you mean? Hardware or App? On the local servers this wasn’t changed.
I’m not sure - I honestly can’t remember if anything was ever populated in this list.
It could be App IP’s because it’s not under the Hardware Info section.
EDIT: Just to clarify - I said it “doesn’t work” because the list is empty, it may not be setup correctly but I do know that I’ve set my local server to store IP’s.
I checked. This is just UI issue. IPs are there. Will fix with https://github.com/blynkkk/blynk-server/issues/1210
why library shows 0.4.1 instead of 5.0.1?
I think you mean 0.5.1 ![]()
Not related to OP topic of IP… but perhaps you have an old project that hasn’t been flashed with latest library?
I wish we could dig further to see what projects are referenced with this data (IP or otherwise)… for example, what I show seems to indicate that I have three projects still running slightly older firmware… but I don’t know which ones.
It also shows my one Python project (I think… 0.1.2), but not my NodeJS one (0.4.7) ??
1h AM ![]()
so supposed I have an old project , why only this old project appears?
