how to solve this problem. i my device wasn’t online yet but i setup my local server. how to connect? and my blynk app cant send auth token
Does this post help?
If u couldnt find a solution from my article above please paste your code so we can get a clearer idea about it.
heres my code
#include <BlynkSimpleEsp8266_SSL.h>
char auth[] = “685a9be9d5414608b5583ad907c1c1b5”;
// Set password to “” for open networks.
char ssid[] = “YourNetworkName”;
char pass[] = “YourPassword”;
did u check whther your server is working , nothing wrong with the code i guess
First… you didn’t properly format your posted code as required in both the Welcome Topic and when you open a new topic ![]()
And you have NO IP or port setting that points toward your Local Server…
https://github.com/blynkkk/blynk-server
