What is
10.0.0.10
and what is
[1300] My IP: 0.0.0.0
What is
10.0.0.10
and what is
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
#include <Ethernet.h>
char auth[] = “c138431aab914b6fbda16dbd13439046”;
IPAddress server_ip (10, 0, 0, 10);
// Mac address should be different for each device in your LAN
byte arduino_mac[] = { 0x90, 0xA2, 0xDA, 0x10, 0x1F, 0xC4 };
IPAddress arduino_ip ( 192, 168, 1, 70);
IPAddress dns_ip ( 8, 8, 8, 8);
IPAddress gateway_ip ( 192, 168, 1, 254);
IPAddress subnet_mask(255, 255, 255, 0);
Blynk.begin(auth, server_ip, 8442, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
// Or like this:
//Blynk.begin(auth, “cloud.blynk.cc”, 8442, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
This is the sketch that i uploaded and the serial monitor gave the earlier mentioned output
@djinn111 Well, you using another person router IPs. You should use yours. Have you tried simple sketch without any settings?
yup, and i keep getting
[0] Blynk v0.3.1
[0] Getting IP…
Any idea guys? If i use a wifi shield will i getthe same error?
@djinn111 @Dmytro i was checking the ethernet shield for weak solder points and found out that it has the w5500 chip instead of the w5100 that i specifically ordered… Also found this:
http://forum.arduino.cc/index.php?topic=329990.0
which says that i have to update the wiznet library or use the IDE from arduino.org. fonna give it a try when i get home.
Cheers
damn. thnks fr tht tip…chkd ur msg, n wnt on 2 chk my shield…sme prob in mine 2…
also found this
i don’t know how to install it though…
@vshymanskyy @Dmytro help? i was able to get an ip using the ethernet 2 dhcpAdressPrint but in the blynk examples if i change the ethernet.h to ethernet2.h i get errors…
Anyone knows how to update using this files above?
