I have Raspberry Pi2 with Raspbian Stretch where I installed Blynk Server 0.32.1.
I start the server:
java -jar /home/pi/Blynk/server-0.32.1-java8.jar -dataFolder /home/pi/Blynk/
and it shows:
Blynk Server 0.32.1-SNAPSHOT successfully started.
All server output is stored in folder '/home/pi/Blynk/logs' file.
Your Admin login email is admin@blynk.cc
Your Admin password is admin
On my iPhone 6S iOS 11.2.2, I installed Blynk application version 2.18.0. In the application I clicked on Create New Account, selected Custom server, specified IP address of my Raspberry Pi and port number 8443, specified my e-mail and password. The creation failed with a message complaining about network connection, although the Blynk log shows a connection and an error about message format:
14:36:24.555 DEBUG- Using SLF4J as the default logging framework
14:36:24.600 INFO - Using data dir '/home/pi/Blynk'
14:36:24.764 DEBUG- -Dio.netty.noUnsafe: false
14:36:24.766 DEBUG- Java version: 8
14:36:24.772 DEBUG- sun.misc.Unsafe.theUnsafe: available
14:36:24.777 DEBUG- sun.misc.Unsafe.copyMemory: available
14:36:24.780 DEBUG- java.nio.Buffer.address: available
14:36:24.783 DEBUG- direct buffer constructor: available
14:36:24.788 DEBUG- java.nio.Bits.unaligned: available, false
14:36:24.788 DEBUG- jdk.internal.misc.Unsafe.allocateUninitializedArray(int): unavailable prior to Java9
14:36:24.788 DEBUG- java.nio.DirectByteBuffer.<init>(long, int): available
14:36:24.789 DEBUG- sun.misc.Unsafe: available
14:36:24.791 DEBUG- -Dio.netty.tmpdir: /tmp (java.io.tmpdir)
14:36:24.792 DEBUG- -Dio.netty.bitMode: 32 (sun.arch.data.model)
14:36:24.798 DEBUG- -Dio.netty.noPreferDirect: false
14:36:24.799 DEBUG- -Dio.netty.maxDirectMemory: 235274240 bytes
14:36:24.799 DEBUG- -Dio.netty.uninitializedArrayAllocationThreshold: -1
14:36:24.805 DEBUG- java.nio.ByteBuffer.cleaner(): available
14:36:24.826 DEBUG- Starting reading user DB.
14:36:25.290 DEBUG- Reading user DB finished.
14:36:25.290 INFO - Region : local. Host : 10.0.1.95.
14:36:25.436 DEBUG- -Dio.netty.eventLoopThreads: 8
14:36:25.598 DEBUG- -Dio.netty.noKeySetOptimization: false
14:36:25.599 DEBUG- -Dio.netty.selectorAutoRebuildThreshold: 512
14:36:25.652 DEBUG- org.jctools-core.MpscChunkedArrayQueue: available
14:36:25.860 DEBUG- -Dio.netty.leakDetection.level: disabled
14:36:25.860 DEBUG- -Dio.netty.leakDetection.targetRecords: 4
14:36:25.871 DEBUG- Loaded default ResourceLeakDetector: io.netty.util.ResourceLeakDetector@e965f5
14:36:27.311 DEBUG- Default protocols (JDK): [TLSv1.2, TLSv1.1, TLSv1]
14:36:27.312 DEBUG- Default cipher suites (JDK): [TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA, TLS_RSA_WITH_AES_128_GCM_SHA256, TLS_RSA_WITH_AES_128_CBC_SHA]
14:36:27.703 DEBUG- -Dio.netty.threadLocalMap.stringBuilder.initialSize: 1024
14:36:27.705 DEBUG- -Dio.netty.threadLocalMap.stringBuilder.maxSize: 4096
14:36:27.785 DEBUG- -Dio.netty.allocator.numHeapArenas: 2
14:36:27.787 DEBUG- -Dio.netty.allocator.numDirectArenas: 2
14:36:27.788 DEBUG- -Dio.netty.allocator.pageSize: 8192
14:36:27.789 DEBUG- -Dio.netty.allocator.maxOrder: 11
14:36:27.790 DEBUG- -Dio.netty.allocator.chunkSize: 16777216
14:36:27.791 DEBUG- -Dio.netty.allocator.tinyCacheSize: 512
14:36:27.792 DEBUG- -Dio.netty.allocator.smallCacheSize: 256
14:36:27.792 DEBUG- -Dio.netty.allocator.normalCacheSize: 64
14:36:27.793 DEBUG- -Dio.netty.allocator.maxCachedBufferCapacity: 32768
14:36:27.794 DEBUG- -Dio.netty.allocator.cacheTrimInterval: 8192
14:36:27.795 DEBUG- -Dio.netty.allocator.useCacheForAllThreads: true
14:36:27.849 DEBUG- -Dio.netty.allocator.type: pooled
14:36:27.850 DEBUG- -Dio.netty.threadLocalDirectBufferSize: 65536
14:36:27.851 DEBUG- -Dio.netty.maxThreadLocalCharBufferSize: 16384
14:36:28.048 INFO - Initializing gmail smtp mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
14:36:29.536 INFO - Didn't find custom user certificates.
14:36:29.545 INFO - Didn't find Let's Encrypt certificates.
14:36:29.545 WARN - You didn't specified 'server.host' or 'contact.email' properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
14:36:29.546 WARN - ATTENTION. Server certificate paths (cert : '/home/pi/Blynk', key : '/home/pi/Blynk') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
14:36:33.073 DEBUG- -Dio.netty.buffer.bytebuf.checkAccessible: true
14:36:33.073 DEBUG- Loaded default ResourceLeakDetector: io.netty.util.ResourceLeakDetector@52a3ff
14:36:33.261 DEBUG- hard.socket.idle.timeout = 15
14:36:33.317 DEBUG- app.socket.idle.timeout = 600
14:36:33.873 DEBUG- hard.socket.idle.timeout = 15
14:36:33.950 DEBUG- -Dio.netty.processId: 12258 (auto-detected)
14:36:33.965 DEBUG- -Djava.net.preferIPv4Stack: false
14:36:33.965 DEBUG- -Djava.net.preferIPv6Addresses: false
14:36:33.969 DEBUG- Loopback interface: lo (lo, 0:0:0:0:0:0:0:1%lo)
14:36:33.973 DEBUG- /proc/sys/net/core/somaxconn: 128
14:36:33.980 DEBUG- -Dio.netty.machineId: b8:27:eb:ff:fe:b4:31:f2 (auto-detected)
14:36:34.166 INFO - Hardware plain tcp/ip server listening at 8442 port.
14:36:34.174 INFO - Hardware SSL server listening at 8441 port.
14:36:34.178 INFO - Application server listening at 8443 port.
14:36:34.181 INFO - HTTP API and WebSockets server listening at 8080 port.
14:36:34.184 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
14:36:34.187 INFO - Mqtt hardware server listening at 8440 port.
14:36:34.245 DEBUG- Adding new user admin@blynk.cc. App : Blynk
14:37:55.036 DEBUG- -Dio.netty.recycler.maxCapacityPerThread: 32768
14:37:55.037 DEBUG- -Dio.netty.recycler.maxSharedCapacityFactor: 2
14:37:55.037 DEBUG- -Dio.netty.recycler.linkCapacity: 16
14:37:55.038 DEBUG- -Dio.netty.recycler.ratio: 8
14:37:55.400 DEBUG- [id: 0x0c33dcab, L:/10.0.1.95:8443 - R:/10.0.1.9:60838] HANDSHAKEN: TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
14:37:55.618 ERROR- Register Handler. Wrong income message format. RegisterMessage{id=18263, command=Register, length=0, body=''}
14:37:55.627 WARN - User not logged. /10.0.1.9:60838. Closing.
14:37:55.667 DEBUG- Discarded inbound message PooledUnsafeDirectByteBuf(ridx: 0, widx: 67, cap: 67) that reached at the tail of the pipeline. Please check your pipeline configuration.
This issue is persistent.
So while the documentation will catch up, it can take time…
