Need assistance. I have created 2 devices within the Web dashboard and that is all good.
But, when I want to add the second device via the Mobile App, it tells me “You have reached devices limit”
If you are on the free plan then there are 2 free devices on offer. Once you have added them, you cannot add more. You can subscribe to plus plan for more devices.
When you add a device in the web console it should automatically appear in the app.
If it’s not appearing then try refreshing the device view, or close and re-open the app.
You can have two devices. They will appear in both the mobile app and the web console, but they will be the same devices.
Device is a device. You add it via web console or via app, the device shows up on both web as well as the blynk app.
I would say, you better delete all the devices n start from scratch.
First create a template, create data streams, place widgets on the web dash(if required)
Copy the provided template id n device name, paste it in your code n upload it to your board.
Now power up your device, open blynk app and click on add device(follow the steps that the app prompts)
After successful adding of the device, you can click the spanner icon n start to add widgets and tie then with the data streams that you created earlier.
This is the whole process to add a device. If you have followed this step correctly and you have added to different devices, then you have run out of devices ( 2 free devices under free plan )
If you want more devices you need to subscribe to plus or pro plan.
Edit: webdash is there so you can control your devices through your computer’s browser. There are only few widgets on webdash n more to come.
So, you can’t have two devices in the web console and ANOTHER two devices in the app, you can have two devices in total, and those same two devices will appear in both the web console and in the app.
Does this help with your understanding of that part of my answer?
your pic is exactly what I am trying to get to (within the 2 device limit), see below.
after the stop start refresh, still no luck.
is it possible that some can have look in the back-end and see what the 2nd device is ?
being that the Water Mang System within the mobile app is the only 1 I see.
I dont remember if there is a option to reconfigure the device from the web console.
If you have configured the button to reset(re config button) the board, then hold it for 10 sec and the board will be in ap mode, now you can go to the app and click on add device.
but I am starting to think there are bugs, see pic below.
How can I now have 3 devices in 1 view and another view show 2 devices and on my Phone App 1 device - where I cannot add another, odd stuff happening.
the pic is clear proof something is on correct somewhere.
