i am trying to make a off grid system but I can’t do it. I have a esp8266 12e nodemcu.
parts.
- 8 channel relay
- ACS712 20 amp.
i have made this code for the relay and it works.
/*New Blynk app with Home Automation
https://srituhobby.com
//Include the library files
#define BLYNK_TEMPLATE_ID "****"
#define BLYNK_DEVICE_NAME "****"
#define BLYNK_AUTH_TOKEN "****"
//Define the relay pins
#define relay1 D0
#define relay2 D1
#define relay3 D2
#define relay4 D3
#define relay5 D4
#define relay6 D5
#define relay7 D6
#define relay8 D7
char ssid[] = "****";//Enter your WIFI name
char pass[] = "*****";//Enter your WIFI password
//Get the button values
BLYNK_WRITE(V0) {
bool value1 = param.asInt();
// Check these values and turn the relay1 ON and OFF relæ 1
if (value1 == 1) {
digitalWrite(relay1, LOW);
digitalWrite(relay1, HIGH);
BLYNK_WRITE(V1) {
bool value2 = param.asInt();
// Check these values and turn the relay2 ON and OFF relæ 2
if (value2 == 1) {
digitalWrite(relay2, LOW);
digitalWrite(relay2, HIGH);
BLYNK_WRITE(V2) {
// Check these values and turn the relay2 ON and OFF relæ 3
if (value2 == 1) {
digitalWrite(relay3, LOW);
digitalWrite(relay3, HIGH);
BLYNK_WRITE(V3) {
// Check these values and turn the relay2 ON and OFF relæ 4
if (value2 == 1) {
digitalWrite(relay4, LOW);
digitalWrite(relay4, HIGH);
BLYNK_WRITE(V4) {
// Check these values and turn the relay2 ON and OFF relæ 5
if (value2 == 1) {
digitalWrite(relay5, LOW);
digitalWrite(relay5, HIGH);
BLYNK_WRITE(V5) {
// Check these values and turn the relay2 ON and OFF relæ 6
if (value2 == 1) {
digitalWrite(relay6, LOW);
digitalWrite(relay6, HIGH);
BLYNK_WRITE(V6) {
// Check these values and turn the relay2 ON and OFF relæ 7
if (value2 == 1) {
digitalWrite(relay7, LOW);
digitalWrite(relay7, HIGH);
BLYNK_WRITE(V7) {
// Check these values and turn the relay2 ON and OFF relæ 8
if (value2 == 1) {
digitalWrite(relay8, LOW);
digitalWrite(relay8, HIGH);
//Set the relay pins as output pins
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
pinMode(relay5, OUTPUT);
pinMode(relay6, OUTPUT);
pinMode(relay7, OUTPUT);
pinMode(relay8, OUTPUT);
pinMode(amp, INPUT);
// Turn OFF the relay
//Initialize the Blynk library
Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
//Run the Blynk library
and this is the code for the amp meter
int adc = analogRead(A0);
float voltage = adc*5/1023.0;
float current = (voltage-2.5)/0.100;
float watt = 12*current;
can somebody help me make this come true.
i want to have the 8 relay on the web and to gauge to se how many amps and watts I use now and how many I have use over time.
like this
best regards Sophus Andreassen.
