Gunner
July 12, 2018, 9:10am
21
@Muhammad_Umair Here is a Bridge option example.
And yes, each device has its own AUTH code as that is the recommended way of running multiple devices, even if in the same project (although then I see no reason to use Bridge… just share data via code and variables and/or vPins)
#11 - The simple, but mystifyingly complex, Bridge
The Bridge is meant to allow totally separate projects to share data, and/or control things between themselves. You can also have just one project with multiple devices, but have any of the 1st device’s Blynk functions triggered directly by Bridge code in the 2nd device… bypassing the App.
As long as the Auth tokens were generated on the same server, then this can even share between different accounts… I think?
Basically, Blynk Br…
Nova
22
I have two wemos d1’s connecting via bridge. I use two different authorisation tokens which is pretty much how the blynk sketch does it. Give it a try. Logically if both wemos’s are using the same auth code perhaps that is causing the problem.
Wemos b led now high all the time
use some serial.print to check the values sent and received… i’m doing this on my mind without arduino ide XD
Wemos A is sending the Data value to pin 10 i checked in blynk app it is recieveing value but not sure if Wemos b is getting the data correctly
i have Wemos A & B on the same token it that a problem?
I told you to use the bridge for a reason, but as you insisted on using the same token for both …I wrote these codes
it Started Working MAN.
YOU ARE THE BEST MAN!!!
THANKS ALOT
i wanted to use bridge but it seems a little complicated and i am not as good programmer as you are man.
thanks alot again. with a simple serial.print statement it started working on wemos b too
koaiwi
July 16, 2018, 5:13am
29
I’ve tried to use to use the bridge between 2 sonoff devices (esp8266 based). After a while both devices just stop communication.
