Can i share data between 2 Wemos D1 R1 using blynk
Hello
I have two Wemos D1 R1 i have programmed the same auth token in both so i can make them both turn on off leds from one app.
but now what i want is that i have attached a potentiometer to one wemos and i want to recieve the reading on the other too.
is it possible ?
Yes, you can do it in different forms…
One of them is
http://docs.blynk.cc/#widgets-other-bridge
What if both the devices have the same token?
You can send the potentiometer value to a virtual pin and in the other wemos you can use http://docs.blynk.cc/#blynk-firmware-blynktimer-blynksyncvirtualvpin to retrieve the updated value using the BLYNK_WRITE function…
i am trying but it isnt working!!
the code in wemos b
int current1;
char auth[] = "673cd76cc5044a49a6cb65fb595e4895";
char ssid[] = "PTCL-BB";
char pass[] = "3553C8A8";
int yy= 0;
//int LED2 = D3;
int LED3 = D5;
  pinMode(D5, OUTPUT);
  pinMode(A0, INPUT);
  Blynk.syncVirtual(V10);
void loop(){
  BLYNK_WRITE(D5) {
 int pinValue = param.asInt();
 if (V10 > 500) {
    digitalWrite(LED3, HIGH); // Turn LED on.
    digitalWrite(LED3, LOW); // Turn LED off.
The Code in Wemos A
  pinMode(A0, INPUT);
  pinMode(D5,OUTPUT);
void switchstate(){
  current1 = analogRead(A0);
  Blynk.virtualWrite(V50,current1);
void loop(){
  switchstate();
Doing this in the setup function only is called 1 time… you must use it at loop function
And use the BLYNK_WRITE(V10) function
i tried in the loop also
you used the blynk_write(v10) function?
Blynk.syncVirtual(V10) calls the execution of BLYNK_WRITE(V10)… if you don’t use that function…
And if you used Blynk.virtualWrite(V50,current1); … you must use Blynk.syncVirtual(V50) and BLYNK_WRITE(V50) in wemos B
where should i write the wemos a or b.
p.s thanks for the support you are a life saver :slight_smile:
Wemos A reads the potentiometer value… send it to V10 for example and at wemos B use syncVirtual(10) at loop function and use BLYNK_WRITE(V10) to get the potentiometer value sent from the wemos A
// WEMOS A //
int current1;
  pinMode(A0, INPUT);
  pinMode(D5,OUTPUT);
void switchstate(){
Blynk.virtualWrite(V10,current1);
void relaystate(){
BLYNK_WRITE(D5) ;
digitalWrite(D5, HIGH);
void relaystate1(){
BLYNK_WRITE(D5) ;
digitalWrite(D5, LOW);
void loop(){
  switchstate();
  if (current1 > 500){
  relaystate();}
  if (current1 < 500){
  relaystate1();}
// WEMOS B //
void loop(){
BLYNK_WRITE(V10){
 BLYNK_WRITE(D5) {
 int pinValue = param.asInt(); // Assigning incoming value from pin V3 to a variable
 if (V10 > 500) {
    digitalWrite(D5, HIGH); // Turn LED on.
    digitalWrite(D5, LOW); // Turn LED off.
Is this ok now?
You know the use of this function?
http://docs.blynk.cc/#blynk-firmware-blynktimer-blynk_writevpin
yes i am trying to make the led on wemos b high.
it is working on wemos A .
when the pot value goes high it turns the on board led on
but it is not working on Wemos B
Wemos A
int PotValue=-1;
  pinMode(A0, INPUT);
  pinMode(D5,OUTPUT);
void SwitchState()
  if (PotValue!=analogRead(A0))
    PotValue=analogRead(A0);
    Blynk.virtualWrite(V10,PotValue);
    digitalWrite(D5, PotValue> 500); //HIGH==TRUE==1
  SwitchState();
Wemos B
BLYNK_WRITE(V10)
  digitalWrite(D5,pinValue > 500);
Wemos A Led is turning On / Off But Wemos B Still not working
Check this… i make a mistake before
