Can I get data from blynk after reboot ESP32?
I can get data when I change numeric input in blynk with this code.
 BLYNK_WRITE(V4)
  time_log = param.asInt();
   now = rtc.now();
   Serial.print("Time Log: ");
   Serial.println(time_log);
  if(now >= next_log){
      next_log = now + (time_log*60);
      Serial.print("Run");
delay(3000);
I can get time_log from BLYNK_WRITE(V4) when I change numeric input in blynk. when I reboot ESP32 it not get data from blynk until I change numeric input in blynk again. Can I get data from blynk after reboot ESP32 ?
Hi !
You can add Blynk.syncVirtual(V4) in your setup.
Read the " Synchronising the output state with the app at startup" section of this topic:
Also the KILLER delay in the void loop. Search “clean void loop”
You can’t use that in the loop, use timers instead
