BLYNK
Can add multiple LED with delay blink
I can’t add more LED with delay blink.
char auth[] = "";
char ssid[] = "";
char pass[] = "";
WidgetLED led1(D7);
WidgetLED ledBlinking(D5);
#define LED_PINBLINK D5
int t1;
// V1 LED Widget is blinking
void blinkLedWidget()
  if (led1.getValue()) {
    led1.off();
    Serial.println("LED on D7: off");
    led1.on();
    Serial.println("LED on D7: on");
  pinMode(LED_PINBLINK, OUTPUT);
  t1 = timer.setInterval(1000, ledBlynk);
  timer.disable(t1);
BLYNK_WRITE(1)
  if (param.asInt()) {
    timer.enable(t1);
    timer.disable(t1);
    digitalWrite(LED_PINBLINK, LOW);
// Change blink interval using virtual pin 2
BLYNK_WRITE(2)
  int interval = param.asInt();
  boolean wasEnabled = timer.isEnabled(t1);
  timer.deleteTimer(t1);
  t1 = timer.setInterval(interval, ledBlynk);
  if (!wasEnabled) {
    timer.disable(t1);
void ledBlynk()
  digitalWrite(LED_PINBLINK, !digitalRead(LED_PINBLINK));
You also cannot properly format posted code… so I fixed your post as per the directions
As for your question… what is your question :stuck_out_tongue:
You can create as many blinking leds as you like
use “case” statement and a flag into the void blinkLedWidget()
:wink:
