Hi
I’m struggling to get a PWM to work on a Raspberry Pi. I’m coding in C++ - as a novice.
My first question is related to WiringPi versus BlynkApiWiringPi:
I followed the example and this installs BlynkApiWiringPi - does this work the same as WiringPi itself? the first difference is that I seem to have to use the GPIO pin numbering and not the Wpi numbering pins. I am able to read inputs but with the GPIO numbering. am I correct in saying that BlynkApiWiringPi uses different pin numbering to WiringPi?
Related to this - to get PWM to work do I use the WiringPi notation like this:
pinMode(pin, PWM_OUTPUT);
pwmWrite(pin, 1024);
or the Blynk notation:
pinMode(pin, OUTPUT);
analogWrite(pin, 800);
I may have a physical wiring problem as well come to think of it - this is the first time I’m doing this. But I am still unsure about the relationship between BlynkApiWiringPi and WiringPi itself.
My current code that is not working is:
#define BLYNK_PRINT stdout
#ifdef RASPBERRY
#include <BlynkApiWiringPi.h>
#else
#include <BlynkApiLinux.h>
#endif
#include <BlynkSocket.h>
#include <BlynkOptionsParser.h>
static BlynkTransportSocket _blynkTransport;
BlynkSocket Blynk(_blynkTransport);
#include <BlynkWidgets.h>
#define motorAfwdpin 13
#define motorAbackwdpin 19
unsigned int uptime; // 1 second intervals
unsigned int pinStatus; // status of BCM 17
unsigned int lastpinStatus = 0; // to toggle
void myTimerEvent() // button widget on V0 or direct access gp17 button
uptime = (millis() / 1000);
Blynk.virtualWrite(V1, uptime);
pinStatus = digitalRead(17);
if(pinStatus != lastpinStatus){
lastpinStatus = pinStatus;
printf("GP17 pin status: %i\n", pinStatus);
if(pinStatus == 1){ // this is to synchronise V1 button if gp17 button is pressed
Blynk.virtualWrite(V0, 1);
printf("forward \n");
pwmWrite(motorAfwdpin, 800);
pwmWrite(motorAbackwdpin, 0);
pwmWrite(motorAfwdpin, 0);
printf("stopped \n");
else{
Blynk.virtualWrite(V0, 0);
printf("backward \n");
pwmWrite(motorAbackwdpin, 1024);
if(millis() >= uptime + 1){ // 1 second intervals
myTimerEvent();
int main(int argc, char* argv[])
pinMode(motorAfwdpin, PWM_OUTPUT);
pinMode(motorAbackwdpin, PWM_OUTPUT);
const char *auth, *serv;
uint16_t port;
parse_options(argc, argv, auth, serv, port);
Blynk.begin(auth, serv, port);
while(true) {
loop();
return 0;
