I’ve already searched for similar topics, but couldn’t find what I was looking for.
Im looking for this:
Button widget on my phone, when pressed a relay (wired to my nodemcu 8266) switches on for a period of lets say 10minutes, then switches of until I press the button again on my phone.
This isn’t a hard code, right? I tested with simple timer and blynk timer but nothing works out.
Anyone that might give it a try?
Did you use a BlynkTimer in Timeout mode, preferably as part of a Lambda function?
Read the “Timeout Timers” section of this document, and don’t forget to declare your BlynkTimer object and add timer.run(); to your void loop.
Once you have this working, if you want to add a slider or time input widget to your app to change the amount of time that the relay stays on for with each button press then you can use the technique described in the "Using variables instead of hard-coded numbers2 section of that document.
You may also need to learn about how to retrieve values from virtual pins, and how to sync the current values when the device starts up. That’s covered here…
Thanks for you answer.
This is the code I now have plotted. This is without the basic #define & #include blah blah
Now I need to setup the blynktimer or simpletimer, to start (10 minute) timer when I have pushed the blynk push button widget on my phone. But I do not know how to include it in my sketch. Any ideas?
Greetings,
Jozef
pinMode(2, OUTPUT); //digital pin 2 (D4) as output.
BLYNK_WRITE(V1) // Executes when the value of virtual pin 1 changes
if(param.asInt() == 1)
// execute this code if the switch widget is now ON
digitalWrite(2,HIGH); // Set digital pin 2 HIGH
// execute this code if the switch widget is now OFF
digitalWrite(2,LOW); // Set digital pin 2 LOW
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// Setup a function to be called every 10s
timer.setInterval(10000L);
@Joepl10 please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
So clearly my “Using Blynk Timer or SimpleTimer” guide isn’t as easy to follow as it should be. Maybe if you can explain which part(s) of that guide you find confusing then I can improve it.
I again tried to look for answers in the Blynk community forums and online. @PeteKnight: I understand the guide completely, I just don’t know how to put it together in my case.
I just want to make a LED burn or relay switch on for a certain amount of time once I’ve pushed the button widget on the blynk app on my iphone.
I came across some piece of coding. Mabye I should give it a try.
So this is what I made out of it. Need to test it, but this is what i’ve made out of it.
#define BLYNK_TEMPLATE_ID "H"
#define BLYNK_DEVICE_NAME "r"
#define BLYNK_AUTH_TOKEN "E"
char ssid[] = "M"; // Enter your Wifi Username
char pass[] = "2"; // Enter your Wifi password
int virtual_pin value = param.asInt();
timer.setTimeout(10000L, []() //After 10 seconds the relay is turned off
digitalWrite(2, LOW);
Hello so this is my code now.
I want to make a button (PUSH) and when I press it the relay or LED or whatever is connected will be powered via NodeMCU ESP8266 for 10seconds and then switches of until I again press the button.
What you think about the code?
I get an error at the ‘’ else digitalwrite low’’ (before void loop) and the error message says:
expected primary-expression before ‘,’ token. I never got this message before and don’t know how to fix it.
Could anyone help and say if this code is good for my ideas about switching on/off?
Greetings,
Jozef
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_AUTH_TOKEN "Lc"
#define relay
int value = 0; //Variable that will store the value of the button that will trigger the relay
BLYNK_WRITE(V1)//Button that activates the relay
if(value == 1){ //If the button that triggers the relay is pressed
digitalWrite(relay, HIGH);
digitalWrite(relay, LOW);
}else
If you used indents better, an placed opening curly brackets on a line of their own, instead of appending them to the end of the previous line, your code would look like this…
if(value == 1)
// missing Blynk connection code in here…
You’d then be able to see that you are missing an opening and closing curly bracket around your digitalWrite(relay, LOW); line of code.
You are also missing pinMode commands in your void setup to allow your digitalWrite commands to work, along with Blynk connection code, Serial.begin commands etc.
#define BLYNK_DEVICE_NAME ""
#define BLYNK_AUTH_TOKEN ""
char ssid[] = "";
char pass[] = "";
#define relay D2
int pinValue = 0; //Variable that will save the button's value
BLYNK_WRITE(V1) //Button that activates the relay
pinValue = param.asInt();
digitalWrite(4, OUTPUT);
Blynk.begin(auth, "'', "");
if(pinValue == 1) //If the relay is activated by the button
else if (pinValue == 0) //If the relay is not activated by the button
digitalWrite(relay, LOW); // assuming relay is active HIGH
And look at the attached screenshot, this is my setup at the Blynk2.0 webpage.
I made a pushbutton with datastream ‘‘relay’’ and set to PUSH mode.
I uploaded the sketch and it is online at Blynk.
But when I press the button nothing happens.
Is there any chance you can spot the fault ???
Hmmm, it appears that we are speaking different languages!
I didn’t tell you to do with your void loop, instead I was explaining what changes you needed to make to your void setup to fix the error message you were getting, and also pointing-out other pieces of code that were missing from your void setup to enable your sketch to work correctly.
I’d suggest that you re-read what I wrote!
For 10 seconds maybe, but no longer now that you’ve removed Blynk.run() from your void loop.
Instead of making random changes to code that you clearly don’t understand, you should either go back to your original code. Or, if you don’t understand your original code either, you should learn more about C++ programming in general.
I am sorry for my last code sketch I was working of 2-3 different sketches and mixed them a little up.
I have basic knowhow on writing codes but I’m just not familiar with connecting it to Blynk.
I normally work with physical buttons and such.
I now made my code complete, so no random changes
But clearly there is something wrong in the connection between Blynk and my NodeMCU
The code uploads fine and Blynk says my device is online, and stays online now.
But once I press the button widget I’ve made, nothing happens.
Is there anyone who could tell me what I’m doing wrong, and could explain it to me with using my code, so not by referring me to manuals and examples that are not related to my problem/situation.
Here is my full code, I would like to hear what you think about it!
char ssid[] = "";
char pass[] = "";
#define relay D1
digitalWrite(5, OUTPUT);
Blynk.begin(auth, "", "");
