Button acts as push instead of switch
I created a simple test project with a switch button that switches V1 from 0 → 1
All i want is that an external led on D4 and an internal led turns on.
The leds turn on and stay on but the button is turning to off again. I want that button on and when i press it the leds turn of and the button also.
What is wrong with my code?
Thx in advance
// vult een textveld in de app op de foon
#define SERIALDEBUG
#include <ESP8266_Lib.h>
char auth[] = "token";
char ssid[] = "sid";
char pass[] = "pass";
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
void sendSeconds() {
  Blynk.virtualWrite(V0, millis() / 1000);
void sendMillis() {
  Blynk.virtualWrite(V1, millis());
BLYNK_WRITE(V1)
  Serial.println("test");
  digitalWrite(13,1);
  digitalWrite(4,1);
  // process received value
  // Set ESP8266 baud rate
  // Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
  timer.setInterval(1000L, sendSeconds);
  timer.setInterval(1000L, sendMillis);
@mikje please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
done and learned something :slight_smile:
Two things:
  1. your button widget in the app needs to be set to Switch not Push
  2. your BLYNK_WRITE(V1) command has no if statement to make it perform different actions when the button is turned on and off. Look at the “Bring it all together” section of this post to see how to do that:
regarding 1) the button is set to switch, but when pressed it goes off within a second
regarding to 2) you are right and I changed my code
#define SERIALDEBUG
char auth[] = "TOKEN";
char ssid[] = "SID";
char pass[] = "PASS";
void sendMillis() {
BLYNK_WRITE(V1)
 if(param.asInt() == 1)
    // execute this code if the switch widget is now ON
    Serial.println("test 1");
  digitalWrite(13,1);
  digitalWrite(4,1);
    // execute this code if the switch widget is now OFF
        Serial.println("test 0");
    digitalWrite(13,0);
  digitalWrite(4,0);
Copying my example exactly makes this line redundant:
This function, which is being called once per second via a timer, is your culprit:
V1 is the virtual pin that your switch widget is attached to.
Thanx very much now it is working as expected. Stupid from me to oversee the Vnumber from the timer
