Issue:
The Blynk node has been performing well for several months but I realized days ago the watering schedule was wrong. Today I found out that the time picked up in the Timer Widget is not set correctly in the app.
This is a short screen-cast showing the issue:
Now that you mention I realize there was an update for the app and did applied. Now running Blynk App 1.9.1, eventhough the issue is still present. I add below a screen cast for clearer explanation. I also notice that it’s related to the time format. When I chose HH:MM the issue is not reproduced. When I chose HH:mm - aa the issue is reproduced.
Followed your advice and to make sure I am in the latest version I did follow:
-Clear app cache and data
-Uninstall Blynk
-Reboot phone
-Install Blynk latest 1.9.1 (122) 17.05.2023 10:59
-Login to Blynk in the app
-Test the issue: still reproduces.
Tryied in another phone that never had Blynk installed and the issue is reproduced too.
Let me know what other relevant information I may send.
Thanks, we somehow missed this bug in am/pm format. There should be no such issue in case of time format without am/pm. We will fix this bug in the next update which should happen at mid/end of the next week.
