Since
Blynk has a problem with SimpleTimer didnt worked together, because of this:
/tmp/759171214/custom/Blynk/src/Blynk/BlynkTimer.h:38:36: error: conflicting declaration 'typedef void (* timer_callback)()'
typedef void (*timer_callback)(void);
In file included from /tmp/759171214/blynk_audio/blynk_audio.ino:35:0:
/tmp/759171214/custom/SimpleTimer/SimpleTimer.h:42:35: error: 'timer_callback' has a previous declaration as 'typedef class std::function<void()> timer_callback'
typedef std::function<void(void)> timer_callback;
/tmp/759171214/blynk_audio/blynk_audio.ino: In function 'void setup()':
/tmp/759171214/blynk_audio/blynk_audio.ino:83:3: error: 'timer' was not declared in this scope
timer.setInterval(1000,soundFreq);
/tmp/759171214/blynk_audio/blynk_audio.ino: In function 'void loop()':
/tmp/759171214/blynk_audio/blynk_audio.ino:130:3: error: 'timer' was not declared in this scope
exit status 1
my code
#include <Arduino.h>
#undef max
#undef min
// SimpleTimer - Version: Latest
#include <FHT.h> //source http://wiki.openmusiclabs.com/wiki/ArduinoFHT?action=AttachFile&do=view&target=ArduinoFHT4.zipt&target=ArduinoFHT4.zip
#include <AudioAnalyzer.h>//source image.dfrobot.com/image/data/DFR0126/library/AudioAnalyzer%20v1.3.zip
#include <WiFi101.h>
#include <BlynkSimpleMKR1000.h>
//------------Initialize the variables for the AUDIO sensor
#define SoundSensorPin A0 //this pin read the analog voltage from the sound level meter
#define VREF 5.0
//to identify which freq band range is the loudest,
// its need to be labelled by its peak num
// Always show the max magnitude from the sound signal
Analyzer Audio = Analyzer(4,5,0);//Strobe pin ->4 RST pin ->5 Analog Pin ->0
//Analyzer Audio = Analyzer();//Strobe->4 RST->5 Analog->0
//String FreqNames[] = {"63", "160","400", "1K","2.5K", "6.25K","16K"};
int FreqNames[] = {63,160,400,1000,2500,6500,16000};
int FreqVal[7];//
int max_index;//
//int hz = 0;
float voltageValue,dB;
//to identify the testperson
int testperson = 1;
// Create instance of WiFi client
WiFiClient client;
char auth[] = "";
char ssid[] = "";
char pass[] = "";
Serial.begin(57600);
Audio.Init();//Init module
timer.setInterval(1000,soundSensor);
//timer.setInterval(1010,soundVol);
//timer.setInterval(1020,testp);
void soundSensor()
Audio.ReadFreq(FreqVal);//return 7 value of 7 bands pass filiter
//Frequency(Hz):63 160 400 1K 2.5K 6.25K 16K
//FreqVal[]: 0 1 2 3 4 5 6 magnitude
max_index = 0;
for(int i=1; i<7; i++) //
if (FreqVal[max_index] < FreqVal[i]) max_index = i;
if(FreqNames[max_index])
Serial.println("Frequenzy: ");
Serial.print(FreqNames[max_index]);
Serial.print("hz");
Blynk.virtualWrite(V0,FreqNames[max_index]);
voltageValue = analogRead(SoundSensorPin) / 1024.0 * VREF;
dB = voltageValue * 50.0;
if(dB)
Serial.println("Volume: ");
Serial.print(dB);
Serial.print("dB");
Blynk.virtualWrite(V1, dB);
delay(20);
if(testperson)
Serial.println("testperson: ");
Serial.print(testperson);
Blynk.virtualWrite(V2, testperson);
delay(40);
// Connects to the WiFi
// If the network does not need a password: WiFi.begin(ssid);
WiFi.begin(ssid, pass);
//delay(10000); // Waits 10 seconds to confirm connection
// Print WiFi strength information
printCurrentNet() ;
// Disconnects from the WiFi
//WiFi.disconnect();
void printCurrentNet() {
// Print the WiFi signal strength:
long rssi = WiFi.RSSI();
Serial.print("Signal strength (RSSI): ");
Serial.print(rssi);
Serial.println(" dBm");
If the Simpletimer is excluded Arduino is verified the code and its connecting but Blynk doesnt seems to read anything
