Blynk.setProperty() command not changing button color
Hi guys
Is it possible to change the infill color from buttons with an incomming variable.
Thx in the meantime :face_with_raised_eyebrow::grin:
What´s a working programm if the visual appearance isn´t right :wink:
You can change widget colour with the Blynk.setProperty() command, as I did in example above.
http://docs.blynk.cc/#blynk-main-operations-change-widget-properties
Why you think I post it under the post above?? :see_no_evil:
I read it of course :grin::grin:
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "Fritzboxxxxxx";
char pass[] = "xxxxxxxxxxxxxxxxxxxxxxxxxx";
byte SwitchMode1 = 0;
byte MainButton = 0;
byte varMainButton = 0;
byte varSwitchMode1 = 0;
WidgetLCD lcd (V101);                                   //LCD Widget attached to Pin V30
  timer.setInterval(100L, Func_Modi);
BLYNK_WRITE(V20)                                                        //MainButton
  MainButton = param.asInt();
  if (MainButton == 1) {
    varMainButton = 1;
  if (MainButton == 0) {
    varMainButton = 0;
BLYNK_WRITE(V21)                                                         //Modus 1, LED ON/OFF
  SwitchMode1 = param.asInt();
  if (SwitchMode1 == 1)  {
    varSwitchMode1 = 1;
  if (SwitchMode1 == 0)  {
    varSwitchMode1 = 0;
void Func_Modi() {
  if ((varSwitchMode1 == 1) && (varMainButton == 1)) {
    lcd.print(0, 0, " MODE 1      ON ");
    lcd.print(0, 1, " LED ON/OFF     ");
    Blynk.setProperty(V23, "color", "#23C48E"); // GREEN
    Blynk.setProperty(V23, "label", "ON"); // ON
  if ((varSwitchMode1 == 1) && (varMainButton == 0)) {
    lcd.print(0, 0, " MODE 1      OFF");
    Blynk.setProperty(V23, "color", "#D3435C"); // RED
    Blynk.setProperty(V23, "label", "OFF"); // OFF
My button number 3 (V23) doesn´t change his color :man_facepalming::roll_eyes:
Good question… if you are having an issue with a project then you should have created a new topic and explained the details, so that others can know what you are actually talking about :stuck_out_tongue:
Have you tested the command on other widgets? Perhaps your sketch process is not getting to the relevant commands… does the LCD command work?
I don’t see V23 used anywhere else in your code… have you got the correct vPin?
Yes, what you see is only a short cutaway from my sketch … lcd works fine, also the values in serial monitor (you don´t see) I get right :thinking::thinking:
OK, I moved this all into an appropriate topic as it has nothing to do with the prior Idea Topic.
Well. we may need to see it all in order to track the logic flow… otherwise we are just guessing.
Here we go, hope you get along with my “programm-chaos” :joy::joy::joy:
I have more modes with I works only if the MainButton is pressed. When a mode is running and an other mode get pressed, the old one switch of and the new pressed one goes on. Now I want, that the active mode, can not be seen only if you read it on LCD (works), it should be visible on the color from the relative button.
char ssid[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxx";
int LedPinD1 = D1;
int DimmValue = 0;
int BlinkValue = 0;
int OutputValue = 0;
byte SwitchMode2 = 0;
byte SwitchMode3 = 0;
byte SwitchMode4 = 0;
byte ClearLCD = 0;
byte varSwitchMode2 = 0;
byte varSwitchMode3 = 0;
byte varSwitchMode4 = 0;
WidgetLED led (V100);                                   //LED Widget attached to Pin V100
  pinMode (LedPinD1, OUTPUT);
  timer.setInterval(1000L, SerialMonitoring);
  lcd.clear();
  varMainButton = 0;
  varSwitchMode1 = 1;
  varSwitchMode2 = 0;
  varSwitchMode3 = 0;
  varSwitchMode4 = 0;
    varMainButton = 1;
    varMainButton = 0;
    varSwitchMode1 = 1;
    varSwitchMode2 = 0;
    varSwitchMode3 = 0;
    varSwitchMode4 = 0;
BLYNK_WRITE(V22)                                                         //Modus 2, LED SZENE
  SwitchMode2 = param.asInt();
  if (SwitchMode2 == 1) {
    varSwitchMode1 = 0;
    varSwitchMode2 = 1;
    varSwitchMode3 = 0;
    varSwitchMode4 = 0;
BLYNK_WRITE(V23)                                                         //Modus 3, LED DIMMER
  SwitchMode3 = param.asInt();
  if (SwitchMode3 == 1) {
    varSwitchMode1 = 0;
    varSwitchMode2 = 0;
    varSwitchMode3 = 1;
    varSwitchMode4 = 0;
BLYNK_WRITE(V24)                                                         //Modus 4, LED BLINKER
  SwitchMode4 = param.asInt();
  if (SwitchMode4 == 1) {
    varSwitchMode4++;
    varSwitchMode1 = 0;
    varSwitchMode2 = 0;
    varSwitchMode3 = 0;
BLYNK_WRITE(V50)                                                         //Clear LCD
  ClearLCD = param.asInt();
  if (ClearLCD == 1) {
    lcd.clear();
BLYNK_WRITE(V25)                                                         //Slider DimmValue
  DimmValue = param.asInt();
BLYNK_WRITE(V26)                                                         //Slider DimmValue
  BlinkValue = param.asInt();
void SerialMonitoring() {
  Serial.print ("varSwitchMode1 = ");
  Serial.println (varSwitchMode1);
  Serial.print ("varSwitchMode2 = ");
  Serial.println (varSwitchMode2);
  Serial.print ("varSwitchMode3 = ");
  Serial.println (varSwitchMode3);
  Serial.print ("varSwitchMode4 = ");
  Serial.println (varSwitchMode4);
  Serial.print ("varMainButton  = ");
  Serial.println (varMainButton);
  Serial.print ("DimmValue      = ");
  Serial.println (DimmValue);
void Func_Modi() {
  led.setValue(OutputValue);
  Blynk.virtualWrite (V102, OutputValue);
  analogWrite(LedPinD1, OutputValue);
    OutputValue = 50;
    Blynk.setProperty(V21, "color", "#23C48E"); // GREEN
    Blynk.setProperty(V21, "label", "ON"); // ON
    OutputValue = 0;
    Blynk.setProperty(V21, "color", "#D3435C"); // RED
    Blynk.setProperty(V21, "label", "OFF"); // OFF
  if ((varSwitchMode2 == 1) && (varMainButton == 1)) {
    lcd.print(0, 0, " MODE 2      ON ");
    lcd.print(0, 1, " LED SZENE      ");
    OutputValue = 150;
    Blynk.setProperty(V22, "color", "#23C48E"); // GREEN
    Blynk.setProperty(V22, "label", "ON"); // ON
  if ((varSwitchMode2 == 1) && (varMainButton == 0)) {
    lcd.print(0, 0, " MODE 2      OFF");
    OutputValue = 0;
    Blynk.setProperty(V22, "color", "#D3435C"); // RED
    Blynk.setProperty(V22, "label", "OFF"); // OFF
  if ((varSwitchMode3 == 1) && (varMainButton == 1)) {
    lcd.print(0, 0, " MODE 3      ON ");
    lcd.print(0, 1, " LED DIMMER     ");
    OutputValue = DimmValue;
  if ((varSwitchMode3 == 1) && (varMainButton == 0)) {
    lcd.print(0, 0, " MODE 3      OFF");
    OutputValue = 0;
  if ((varSwitchMode4 == 1) && (varMainButton == 1)) {
    lcd.print(0, 0, " MODE 4      ON ");
    lcd.print(0, 1, " LED BLINKER    ");
    OutputValue = 50;
    Blynk.setProperty(V24, "color", "#23C48E"); // GREEN
    Blynk.setProperty(V24, "label", "ON"); // ON
  if ((varSwitchMode4 == 1) && (varMainButton == 0)) {
    lcd.print(0, 0, " MODE 4      OFF");
    OutputValue = 0;
    Blynk.setProperty(V24, "color", "#D3435C"); // RED
    Blynk.setProperty(V24, "label", "OFF"); // OFF
To be clear… you are trying to change the infill colour of a button that is ON, correct? Because we cannot change the OFF infill colour, only the outline.
That little example I provided was a workaround that basically had a button ON all the time and only reacted to the attempted state change… I don’t see that happening in your code.
I also showed that example here…
If it´s only possible to change color when it´s ON would be also okay, better than no color…:smiley:
Well as long as your App and libraries are up to date, I don’t see why something like Blynk.setProperty(V24, "color", "#D3435C"); // RED wouldn’t work. I use those commands all the time for various widgets and in many projects.
Do you have one of your working sketches by hand? Both app and librarys are at the newest versions
I have them posted already… follow and read the rest of that topic link I gave you above.
Have just read the topic you post above… and yes it works, so I can suspend an error with my libs. Fundamentally, my sketch doesn´t works different, only that I compare to values and say, if both are true, the button should change his color else it should remain with his “old” color. The main difference between us two sketches lies where the lines to change color :astonished::astonished:
are written. You put them in a Blynk function and I outside in an extra function where I compare the values.
I redraft my original question:
How to change the background color from a button in a function outside the Blynk-function? :kissing:
Well, I can’t dig through your whole sketch… but my example is quite different than what I see in your code…
I don’t really treat the button function as a normal one… The button is set to be ALWAYS ON, and the function just senses that the button was turned OFF then toggles two variables, one which is what would be used in another function to do something, and the other to track the colour to use, then turns the button back on but with a different colour (probably possible to do both with one variable, but need to take into consideration the possible inverted state vs need)
You would need to make multiple copies of that example, one for each button you use, but use the ButtonState variable (renamed for each new button) to control whatever you want to.
Doesn’t matter where the command is (LOOK at all my other colour changing examples)… just as long as it is in a valid function or process.
Hello to all lovers of BLYNK!
I encountered an inexplicable effect, when I add code to the sketch, the color of the button does not change, although other parameters change the same as before.
I use blynk together with mysensors, the mutual influence of two libraries is possible, geeks help!
I will explain - I checked on a simple code how the color of the button changes and it worked but when the code became more complex, the color stopped changing.
Maybe add some serial print statements around the code in question to ensure that it is actually being called and that it you’re passing any variables then the values are what you expect them to be.
It’s also worth checking that if you have multiple devices then you have the widget connected to the device that you are running the code on.
It seems to be understood, the access code to the widget parameters must necessarily be in BLYNK_WRITE(), if the code is in SUBFUNCTION, then the parameters are no longer available…
WORKED:
BLYNK_WRITE(V0){
if(snd485Msg(101,0,1,param.asInt()))
    Blynk.setProperty(sensorID, "color", "#2cbca3");
    Blynk.setProperty(sensorID, "color", "#D3435C");
NOT WORKED:
BLYNK_WRITE(V0){
snd485Msg(param.asInt());
void snd485Msg(int params){
some code
if(flag)
Why???’
@Yury please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
