I am working on a project that requires the Blynk server to be able to move from location to location. So I have configured my RPi 3 +B to be AP and a hotspot to have direct access via WIFI to the Blynk server but the Blynk app losers connectivity when I remove the Ethernet cable.
I know it’s hard to explain all the gritty details in a forum post. but combining the subject with the msg, you dont need any internet access… and you probably have a battery pack or something you are using to make the pi mobile? Why are you plugging in the ethernet at all?
so, you have the pi up and running with wifi in ap mode. the clients and the app connect just fine. you plug in the ethernet cable, its still works just fine, then you unplug the ethernet cable and the app quits?
hi Ivennard thanks for the reply
Im using a RPi3+B and its going to be installed in a dune buggy, the reason for ethernet is for ssh from my pc
the WIFI connectivity between phone and pi works until I until remove the Ethernet cable
the instructions I followed is related to that
ahhh you did the bridge. ok. im with you now. having a bridge would knock out the other link, even though you would’nt think it would/should.
You’ll have to weigh that out for yourself to see what you want down, it sounds like you would rather go without the bridge from your post. So i would undo it.
Now that i think i understand better, i would make an AP with static address from the wlan, offer dhcp… then make the eth0 a static address as well, offering dhcp. remove the bridge setup. when you plug your laptop in, you’ll be able to control the pi, and the as long as blynk server is using the wlan adaptor, all your clients will be able to report in.
that makes sense
old setup ?
oh so this is running a local Blynk server that should control the RPi3 gpio as well so once I remove the bridge ill get back of the gpio or if you the link on that please send it
Hi Ivennard I have applied all steps of offical Blynk documents and still no luck
Still can connect to Blynk without an internet connection, I have tried removing the iptables like you said as well same thing
so what I done was setup the AP without a bridge and nothing extra followed by the local Blynk server
there must be something Im missing here
I cant really find a doc for what i was thinking about, its probably not the norm, but i was basically taking the AP idea from the past link, skipping the routing and natting.
Then, setup the eth0 the same way. you would have two interfaces that are statically assigned and handing out addresses. Too bad the laptop didnt have wireless. problem would be solved.
