Hi!
It’s possible install the Blynk local server on a panel with Windows CE Core 5.0 operating system?
I’ve installed it on a Raspberry but every 3-4 days the server go down. I would try on my Eaton XV-102 panel plc!
Thanks a lot
Hi!
Thanks a lot
Why? Did you check server logs?
I don’t know why…
Not yet… how can I check the log file?
By opening it
. It is called blynk.log.
It’s been running rockstable on my Pi for years. I wouldn’t try Windows CE in a million years… shudders.
Probably something with your setup not quite 100% OK.
Very strange… the log file said only “22:24:43.620 INFO - xxxxxxx.xxxxx@gmail.com Blynk-app joined.” (It’s my last login)
But from the app I read “Offline since 6:42 AM nov 1,2017”
This mean that the server it’s ok and my arduino sometime loose the connection?
In this case, I don’t understand because the Arduino sketch loop correctly (my domotic work correctly with the phisical button)
Thanks for the help and sorry for my english…
You can enable debug logging from the server.properties file and see more info.
I can’t find the file “server.properties” I’ve search it in “/home/pi/” Where I can find it?
If you haven’t made it, you would not find it.
An example and instructions are: https://github.com/blynkkk/blynk-server#blynk-server here (where you also got the local server jar file).
Ok I think that the problem is on my sketch, not in the server.
At the beginning I had a problem beacuse when my arduino loose the connection to the Raspberry, the Arduino’s sketch was blocked until the connection was restored. This is not good because I need my domotic sketch continues to work though the server go offline.
So I decide to check the connection in the main loop. If the connection falling down i stop to call “Blynk.run();”
This work but has a defect: When the connection is restored I can’t realize that the connection is on… so I can’t recall “Blynk.run();”.
The question is: How can I loop my sketch without stop il when the connection falling down?
P.S. I’m realy sorry for my english! It’s very bad… I know
Been covered many, many times on the forum. Try the search facility but use the most recent results.
Ok, I search and found that the problem may be the “Blink.begin” instruction, so I’ve subsitute that with “Blink.config” and I call the instruction “Blink.run” only if “Blink.connect” is = true. It’s correct?
This is the part that I’ve changed in my sketch. I can’t test it today… may be tomorrow. Can somebody tell me if it’s right?
#include <Ethernet.h>
char auth[] = "********************************";
IPAddress server_ip (192, 168, 1, 150);
#define W5100_CS 10
#define SDCARD_CS 4
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.config(auth, server_ip, 8442);
.... Rest of the void setup
boolean blynkConnesso = Blynk.connect();
if (blynkConnesso)
... Rest of the void loop
May be it’s wrong… I think that I must use Blynk.connected(), not Blynk.connect(). Right?
Depends on your application, each similar looking commands are different commands for different reasons.
http://docs.blynk.cc/#blynk-firmware-connection-management-blynkconnect
BLYNK_CONNECTED() {
// Your code here gets ran each time Blynk connects to the server i.e. after a disconnection
http://docs.blynk.cc/#blynk-firmware-virtual-pins-control-blynk_connected
if (Blynk.connected()) {
Blynk.run(); // only runs this command if connected to server
Blynk.connect(); // this command will attempt to reconnect, only if disconnected, with default timeout of 30 seconds
// perhaps better ran in a timed loop every 5min or so
timer.run(); // runs this command all the time
A post was split to a new topic: If i need to install Local Blynk Server to write ip address and my own mac address in my code or not?
