Hi, I thank you for the suggestions I hope to be able to put them into practice.
… you will surely have understood that I am not a programmer …
I have made the suggested changes, below the new code, I hope I have understood and made the right changes.
… at the moment you do not disconnect anymore from blynk but the visualization on LCD is still fast …
I’m working on a scretch to learn how the Timer function works …
//--------------------- include librerie utilizzate ----------------------------
#include <DHT.h>
#include <Wire.h>
#include <Adafruit_ADS1015.h>
Adafruit_ADS1115 ads; /* Use this for the 16-bit version */
//--------------------- parametri connessione wi-fi + blynk ----------------------------
char auth[] = "56xxxxxxxxxx95"; // token Serra Domotica
char ssid[] = "TISxxxxxx";
char pass[] = "xxxxxxxx";
//--------------------- parametri LCD ----------------------------
int lcdColumns = 16; // set the LCD number of columns
int lcdRows = 2; // set the LCD number of rows
LiquidCrystal_I2C lcd(0x27, lcdColumns, lcdRows); // set LCD address, number of columns and rows
//--------------------- definizione variabili ---------------------
#define DHT1PIN D7
#define DHT1TYPE DHT22
DHT dht1(DHT1PIN, DHT1TYPE);
float h1 = dht1.readHumidity();
float t1 = dht1.readTemperature();
float adc0 = ads.readADC_SingleEnded(0); //fotocellula
float adc1 = ads.readADC_SingleEnded(1); //umidita Sx
float adc2 = ads.readADC_SingleEnded(2); //umidita Dx
float adc3 = ads.readADC_SingleEnded(3); //livello serbatorio
void setup(){
Serial.begin(9600); // console debug
Blynk.begin(auth, ssid, pass); // avvio connessione
Wire.begin();
dht1.begin(); // set DHT22
ads.setGain(GAIN_ONE); // set valore ADS1115 --> 1x gain +/- 4.096V 1 bit = 2mV 0.125mV
ads.begin(); // set Adafruit_ADS1015
lcd.init(); // set LCD
lcd.backlight(); // accensione LCD
//--------------------- definizione PIN ---------------------
pinMode(D0, OUTPUT);// rele soglia <25
//pinMode(D1);// SDA --> LCD + ADS1115
//pinMode(D2);// SLC --> LCD + ADS1115
pinMode(D3, OUTPUT);// allarme sensore acqua
//pinMode(D4);// RELE LAMPADA 1 via Blynk
//pinMode(D5);// RELE LAMPADA 2 via Blynk
pinMode(D6, OUTPUT);// rele soglia >25
//pinMode(D7);// DHT 22
pinMode(D8, OUTPUT);// inverter BC237
pinMode(D9, INPUT);// sensore acqua
//--------------------- assegnazione valore iniziale PIN ---------------------
digitalWrite(D0, HIGH);
digitalWrite(D3, LOW);
digitalWrite(D4, LOW);
digitalWrite(D5, LOW);
digitalWrite(D6, LOW);
digitalWrite(D8, LOW);
Serial.print ("IP Locale -->");
Serial.println (WiFi.localIP());
Serial.print ("Connessione Blynk OK! ");
Serial.println (Blynk.connected());
Serial.println ("");
void sensoreDHT(){
t1 = ((int) (t1 * 10) / 10.0);
h1 = ((int) (h1 * 10) / 10.0);
Blynk.virtualWrite(10, t1); // virtual pin
Blynk.virtualWrite(11, h1); // virtual pin
// Check if any reads failed and exit early (to try again).
if (isnan(t1) || isnan(h1)) {
Serial.println("Failed to read from DHT #1");
else {
Serial.print("Temperatura interna: ");
Serial.print(t1);
Serial.print ("");
Serial.println(" gradi /"),(h1);
Serial.print("Umidita' interna: ");
Serial.print(h1);
Serial.println(" %");
delay(2000);
if(t1 < 21)
Blynk.virtualWrite(V1, 255);
digitalWrite(D0, LOW); //accende alimenatore cella Peltier
Blynk.virtualWrite(V1, 0);
digitalWrite(D0, HIGH); //spegne alimenatore cella Peltier
if(t1 > 25)
Blynk.virtualWrite(V2, 255);
digitalWrite(D8, LOW); //inverter cella Peltier
Blynk.virtualWrite(V2, 0);
digitalWrite(D8, HIGH); //spegne inverter cella Peltier
void ads1115(){
int16_t adc0, adc1, adc2, adc3;
// Fotocellula - Luminosita
Serial.print("IN0 Fotocellula: "); Serial.print(adc0);
float Luminosita = (adc0);
Serial.print("\ Luminosita: "); Serial.println(Luminosita/32767*100);
Blynk.virtualWrite(V7, (100-Luminosita/32767*100)); // virtual pin
Serial.println(" ");
// Umidità Sx
Serial.print("IN1 umiditaSx : "); Serial.print(adc1);
float umiditaSx = (adc1);
Serial.print("\ Umidita' terreno Sx: "); Serial.println(umiditaSx/32767*100, 2);
Blynk.virtualWrite(V5, (100-umiditaSx/32767*100)); // virtual pin
float SX = (100-umiditaSx/32767*100);
// Umidità Dx
Serial.print("IN2 umiditaDx : "); Serial.print(adc2);
float umiditaDx = (adc2);
Serial.print("\ Umidita' terreno Dx : "); Serial.println(umiditaDx/32767*100, 2);
Blynk.virtualWrite(V6, (100-umiditaDx/32767*100)); // virtual pin
float DX = (100-umiditaDx/32767*100);
if ((DX <= 45) || (SX <= 45))
{ digitalWrite(D3,HIGH); //Accendi led
Blynk.virtualWrite(V3, 255);
else {
digitalWrite(D3,LOW); //Spegni led
Blynk.virtualWrite(V3, 0);
delay(1000); //Attende due secondi
// Livello serbatoio
Serial.print("IN3 livello acqua: "); Serial.print(adc3);
float livello = (adc3);
Serial.print("\ Livello acqua : "); Serial.println(livello/32767*100, 2);
Blynk.virtualWrite(V8, (100-livello/32767*100)); // virtual pin
float LV = ((100-livello/32767*100));
if (LV <= 30)
Blynk.virtualWrite(V4, 255);
else {
Blynk.virtualWrite(V4, 0);
//------------------ visualizzazione LCD ------------
void LCD(){
lcd.clear();
lcd.setCursor(2, 0);//colonna e riga del display
lcd.print("SERVER BLYNK");
lcd.setCursor(0,1);
if (!Blynk.connected()){
lcd.print("NON CONNESSO");}
else{
lcd.setCursor(0,1);
if (Blynk.connected()){
lcd.print(" CONNESSO");
timer.setTimeout(60000,Temper_Serra);}
void Temper_Serra(){
float T = dht1.readTemperature();
T = ((int) (T * 10) / 10.0);
Serial.print("temperatura lcd : "); Serial.println(T);
lcd.clear();
lcd.setCursor(1, 0);//colonna e riga del display
lcd.print("Temper. Serra");
lcd.setCursor(4,1);//colonna e riga del display
lcd.print(T,2);
lcd.setCursor(11,1);//colonna e riga del display
lcd.print("%");
timer.setTimeout(60000,Umidita_Serra);
void Umidita_Serra(){
float H = dht1.readHumidity();
H = ((int) (H * 10) / 10.0);
Serial.print("umidita' lcd : "); Serial.println(H);
lcd.clear();lcd.setCursor(2, 0);//colonna e riga del display
lcd.print("Umidita' Serra");
lcd.print(H,2);
lcd.print("%");
timer.setTimeout(60000,Luminosita);
void Luminosita(){
float Luminosita = adc0;
lcd.clear();
lcd.print("Luminosita'");
lcd.print(100-Luminosita/32767*100, 2);
lcd.print("%");
timer.setTimeout(60000, Umidita_SX);
void Umidita_SX(){
float umiditaSx = adc1;
lcd.clear();
lcd.print("Umidita' SX'");
lcd.print(100-umiditaSx/32767*100, 2);
lcd.print("%");
timer.setTimeout(60000, Umidita_DX);
void Umidita_DX(){
float umiditaDx = adc2;
lcd.clear();
lcd.print("Umidita' DX'");
lcd.print(100-umiditaDx/32767*100, 2);
lcd.print("%");
timer.setTimeout(60000, Livello_acqua);
void Livello_acqua(){
float LV = (100-adc3/32767*100, 2);
if (LV <= 30){
lcd.clear();
lcd.setCursor(4, 0);//colonna e riga del display
lcd.print("ALLARME");
lcd.setCursor(0,1);//colonna e riga del display
lcd.print("SERBATOIO VUOTO");
else{
lcd.clear();
lcd.print("Livello acqua");
lcd.setCursor(5,1);//colonna e riga del display
lcd.print(LV, 2);
lcd.print("%");
timer.setTimeout(60000, LCD);
void loop(){
timer.setInterval(5000,ads1115);
timer.setInterval(60000,sensoreDHT);
LCD(); Temper_Serra(); Umidita_Serra();
Umidita_DX(); Umidita_SX(); Livello_acqua();
