DHT sensor is lost or failed ?
I saw that you have redundancy between void ads1115() and other void !
timer.setInterval(5000,ads1115);
failed…
your code is very poorly structured
too many redundancies
Alexis, how could I fix it?
… I tried with the varibaili goblali but I can not make it work …
… if I exclude the display on the LCD, for how I thought it works even if it is badly written
Alexis, so far I’ve made simpler projects with blynk, this is the first time I’ve done a more complex project …
the difficulties I am encountering is the simultaneous display of the data I send to Blynk also on LCDs
I will fix that for you soon, if you can wait till tomorrow
I have to edit your code and manage it
Alexis, of course I’m waiting!
thank you so much…
I hope to learn a lot from your directions …
Salvatore,
Learn that and try it
As you can see, I managed all your sketch
I can’t test it because I’ve no ADS1015,
but , code compiles without any error on my IDE.
waiting for your comments
//--------------------- include librerie utilizzate ----------------------------
#include <DHT.h>
#include <Wire.h>
#include <Adafruit_ADS1015.h>
//#include <SimpleTimer.h> not needed , already included with blynk
Adafruit_ADS1115 ads; /* Use this for the 16-bit version */
//--------------------- parametri connessione wi-fi + blynk ----------------------------
char auth[] = "56xxxxxxxxxx95"; // token Serra Domotica
char ssid[] = "TISxxxxxx";
char pass[] = "xxxxxxxx";
//--------------------- parametri LCD ----------------------------
int lcdColumns = 16; // set the LCD number of columns
int lcdRows = 2; // set the LCD number of rows
LiquidCrystal_I2C lcd(0x27, lcdColumns, lcdRows); // set LCD address, number of columns and rows
//--------------------- definizione variabili ---------------------
#define DHT1PIN D7
#define DHT1TYPE DHT22
DHT dht1(DHT1PIN, DHT1TYPE);
float adc0 = ads.readADC_SingleEnded(0); //fotocellula
float adc1 = ads.readADC_SingleEnded(1); //umidita Sx
float adc2 = ads.readADC_SingleEnded(2); //umidita Dx
float adc3 = ads.readADC_SingleEnded(3); //livello serbatorio
float livello, Luminosita , umiditaSx , umiditaDx , DX, SX, LV , H , T, t1, h1 ;
Serial.begin(115200); // console debug
Blynk.begin(auth, ssid, pass); // avvio connessione
Wire.begin();
dht1.begin(); // set DHT22
ads.setGain(GAIN_ONE); // set valore ADS1115 --> 1x gain +/- 4.096V 1 bit = 2mV 0.125mV
ads.begin(); // set Adafruit_ADS1015
lcd.init(); // set LCD
lcd.backlight(); // accensione LCD
//--------------------- definizione PIN ---------------------
pinMode(D0, OUTPUT);// rele soglia <25
//pinMode(D1);// SDA --> LCD + ADS1115
//pinMode(D2);// SLC --> LCD + ADS1115
pinMode(D3, OUTPUT);// allarme sensore acqua
//pinMode(D4);// RELE LAMPADA 1 via Blynk
//pinMode(D5);// RELE LAMPADA 2 via Blynk
pinMode(D6, OUTPUT);// rele soglia >25
//pinMode(D7);// DHT 22
pinMode(D8, OUTPUT);// inverter BC237
pinMode(D9, INPUT);// sensore acqua
//--------------------- assegnazione valore iniziale PIN ---------------------
digitalWrite(D0, HIGH);
digitalWrite(D3, LOW);
digitalWrite(D4, LOW);
digitalWrite(D5, LOW);
digitalWrite(D6, LOW);
digitalWrite(D8, LOW);
Serial.print ("IP Locale -->");
Serial.println (WiFi.localIP());
Serial.print ("Connessione Blynk OK! ");
Serial.println (Blynk.connected());
Serial.println ("");
//--------------------- TIMERS iniziale ---------------------
timer.setInterval(500000, LCD); //7x60000 + margin, time needed to execute all the functions, could be adjusted if you have to change '60000' intervals
}//end setup
//------------------ visualizzazione LCD ------------
void LCD() {
lcd.clear();
lcd.setCursor(2, 0);//colonna e riga del display
lcd.print("SERVER BLYNK");
lcd.setCursor(0, 1);
if (!Blynk.connected()) {
lcd.print("NON CONNESSO");
else {
if (Blynk.connected()) {
lcd.print(" CONNESSO");
timer.setTimeout(60000, Temper_Serra);
void Temper_Serra() {
sensoreDHT();//call sensor
Serial.print("temperatura lcd : "); Serial.println(t1);
Serial.println(" ");
lcd.clear();
lcd.setCursor(1, 0);//colonna e riga del display
lcd.print("Temper. Serra");
lcd.setCursor(4, 1); //colonna e riga del display
lcd.print(t1, 2);
lcd.setCursor(11, 1); //colonna e riga del display
lcd.print("%");
timer.setTimeout(60000, umidita);
void umidita() {
Serial.print("umidita' lcd : "); Serial.println(h1);
lcd.clear(); lcd.setCursor(2, 0); //colonna e riga del display
lcd.print("Umidita' Serra");
lcd.print(h1, 2);
lcd.print("%");
timer.setTimeout(60000, luminosita);
// Fotocellula - Luminosita
void luminosita() {
Luminosita = adc0;
Serial.print("IN0 Fotocellula: "); Serial.print(adc0);
float Luminosita = (adc0);
Serial.print("\ Luminosita: "); Serial.println(Luminosita / 32767 * 100);
Blynk.virtualWrite(V7, (100 - Luminosita / 32767 * 100)); // virtual pin
lcd.clear();
lcd.print("Luminosita'");
lcd.print(100 - Luminosita / 32767 * 100, 2);
lcd.print("%");
timer.setTimeout(60000, Umidita_SX);
// Umidità Sx
void Umidita_SX() {
umiditaSx = adc1;
Serial.print("IN1 umiditaSx : "); Serial.print(adc1);
umiditaSx = (adc1);
Serial.print("\ Umidita' terreno Sx: "); Serial.println(umiditaSx / 32767 * 100, 2);
Blynk.virtualWrite(V5, (100 - umiditaSx / 32767 * 100)); // virtual pin
SX = (100 - umiditaSx / 32767 * 100);
lcd.clear();
lcd.print("Umidita' SX'");
lcd.print(100 - umiditaSx / 32767 * 100, 2);
lcd.print("%");
timer.setTimeout(60000, Umidita_DX);
// Umidità Dx
void Umidita_DX() {
umiditaDx = adc2;
Serial.print("IN2 umiditaDx : "); Serial.print(adc2);
umiditaDx = (adc2);
Serial.print("\ Umidita' terreno Dx : "); Serial.println(umiditaDx / 32767 * 100, 2);
Blynk.virtualWrite(V6, (100 - umiditaDx / 32767 * 100)); // virtual pin
DX = (100 - umiditaDx / 32767 * 100);
if ((DX <= 45) || (SX <= 45))
{ digitalWrite(D3, HIGH); //Accendi led
Blynk.virtualWrite(V3, 255);
else {
digitalWrite(D3, LOW); //Spegni led
Blynk.virtualWrite(V3, 0);
lcd.clear();
lcd.print("Umidita' DX'");
lcd.print(100 - umiditaDx / 32767 * 100, 2);
lcd.print("%");
timer.setTimeout(60000, Livello_acqua);
// Livello serbatoio
void Livello_acqua() {
LV = (100 - adc3 / 32767 * 100, 2);
Serial.print("IN3 livello acqua: "); Serial.print(adc3);
livello = (adc3);
Serial.print("\ Livello acqua : "); Serial.println(livello / 32767 * 100, 2);
Blynk.virtualWrite(V8, (100 - livello / 32767 * 100)); // virtual pin
LV = ((100 - livello / 32767 * 100));
if (LV <= 30)
Blynk.virtualWrite(V4, 255);
else {
Blynk.virtualWrite(V4, 0);
livello = (adc3);
if (LV <= 30)
lcd.clear();
lcd.setCursor(4, 0);//colonna e riga del display
lcd.print("ALLARME");
lcd.setCursor(0, 1); //colonna e riga del display
lcd.print("SERBATOIO VUOTO");
else {
lcd.clear();
lcd.print("Livello acqua");
lcd.setCursor(5, 1); //colonna e riga del display
lcd.print(LV, 2);
lcd.print("%");
void sensoreDHT() {
t1 = dht1.readTemperature();
h1 = dht1.readHumidity();
t1 = ((int) (t1 * 10) / 10.0);
h1 = ((int) (h1 * 10) / 10.0);
Blynk.virtualWrite(10, t1); // virtual pin
Blynk.virtualWrite(11, h1); // virtual pin
// Check if any reads failed and exit early (to try again).
if (isnan(t1) || isnan(h1)) {
Serial.println("Failed to read from DHT #1");
else {
Serial.print("Temperatura interna: ");
Serial.print(t1);
Serial.print ("");
Serial.println(" gradi /"), (h1);
Serial.print("Umidita' interna: ");
Serial.print(h1);
Serial.println(" %");
if (t1 < 21)
Blynk.virtualWrite(V1, 255);
digitalWrite(D0, LOW); //accende alimenatore cella Peltier
Blynk.virtualWrite(V1, 0);
digitalWrite(D0, HIGH); //spegne alimenatore cella Peltier
if (t1 > 25)
Blynk.virtualWrite(V2, 255);
digitalWrite(D8, LOW); //inverter cella Peltier
Blynk.virtualWrite(V2, 0);
digitalWrite(D8, HIGH); //spegne inverter cella Peltier
Alexis, thank you so much!
Your code works, do not disconnect from Blynk and display the data on the LCD, I have only readjusted the intervals of the various functions.
I think the main mistake I made was to keep the LCD display separate from the various functions. I have to understand better the functioning of the Timer which is still unclear to me.
I found that once the cycle is over, the DHT sensor data is lost (I am attaching screenshots of the serial monitor), which are restored shortly thereafter.
thank you so much.
