BLYNK
Blynk.notify not working
I am able to receive the image captured by esp 32 cam on blynk but not the notifications.
I used this same code few days back, then it was working , but now it’s not I don’t understand why. I’ve already tried reinstalling the app and making a new project and it is not working. I tried this on both android and iOS.
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT
//define CAMERA_MODEL_ESP_EYE
//#define CAMERA_MODEL_M5STACK_PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE
#define CAMERA_MODEL_AI_THINKER
#include "camera_pins.h"
#define LED 4
#define BUTTON 15
const char* ssid = "";
const char* password = "";
char auth[] = "";
String my_Local_IP;
void startCameraServer();
void capture()
  digitalWrite(LED,HIGH);
  uint32_t number = random(40000000);
  Blynk.notify("Someone is at the door..");
 // Blynk.notify("Someone is at the door..");
  Serial.println("http://"+my_Local_IP+"/capture?_cb="+ (String)number);
  Blynk.setProperty(V1, "urls", "http://"+my_Local_IP+"/capture?_cb="+(String)number);
  digitalWrite(LED,LOW);
  pinMode(LED,OUTPUT);
  Serial.setDebugOutput(true);
  Serial.println();
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  //init with high specs to pre-allocate larger buffers
  if (psramFound()) {
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 10;
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
#if defined(CAMERA_MODEL_ESP_EYE)
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  sensor_t * s = esp_camera_sensor_get();
  //initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1);//flip it back
    s->set_brightness(s, 1);//up the blightness just a bit
    s->set_saturation(s, -2);//lower the saturation
  //drop down frame size for higher initial frame rate
  s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE)
  s->set_vflip(s, 1);
  s->set_hmirror(s, 1);
#endif
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.print("Camera Ready! Use 'http://");
  Serial.print(WiFi.localIP());
  my_Local_IP = WiFi.localIP().toString();
  Serial.println("' to connect");
  Blynk.begin(auth, ssid, password);
  if(digitalRead(BUTTON) == LOW)
  capture();
What Blynk library version are you using?
Latest one. I,ve tried with older ones but still not working.
Please give the actual version number of the Blynk library that you are using.
Blynk by Volodymyr Shymanskyy version1.0.0-beta.3
Uninstall this and install version 0.6.1
Re-compile your code and re-test.
Thank you very much. The problem is solved.
Same issue here, thanks for the solution!
thank you so much
