Well, not all my devices run on Blynk. Most run on Tasmota or other software I developed. Also particularly Tasmota leaves no memory to include Blynk library on an ESP8266.
My wife likes the ease of use of the Blynk App despite its old fashioned design (I will suggest to the developer team to create some different and more exciting skins).
To combine the two requirements I run a Wemos D1 mini board to run Blynk for my non-Blynk devices. It communicates with the controlled devices through MQTT. Now I can power on or dim a light or change the scheme etc. with the Blynk GUI.
At the same time I can still operate these devices with Domoticz and other means.
My program operates as the GUI for one Arilux-LC01 and two ESP01s. As the Wemos has 127 virtual pins you may add more devices.
Arilux-LC01:
Video
Photo of Blynk App:
Program:
Blynk to MQTT bridge
Version 1.0 9. Feb 2018
Funtion: Use Blynk GUI to control MQTT attached devices
Pin assignments:
* Wemos D1 mini
Blynk Virtual Pins: 127 pins available
1. Kitchen Top control (Arilux LC01 running Tasmota)
V0: ON OFF Button
V1: Dimmer slider
V2: Speed slider
V3: Color select
V4: Fade switch
V5: Scheme slider
2. Kitchen top high (ESP01 running Tasmota)
V6: ON OFF Button upper row lights
3. Kitchen top low (ESP01 running Tasmota)
V7: ON OFF Button lower row lights
4. For own purposes
V13: ON OFF LED
V14: UP LED
Bill of material:
-Wemos D1 mini
-1000uF capacitor (I found that a capacitor around 5V and Ground increases stability of the Wemos D1)
-5V 750mA Power Supply
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
// Set ESP8266 Serial object
// Blynk
//#define BLYNK_DEBUG
//#define BLYNK_PRINT Serial
int ONOFF_LED = V13;
int UP_LED = V14;
long int last_UP_change = millis();
bool runn = 1;
bool lamp_on;
bool lamp23_on;
bool lamp24_on;
int brightness;
int current_activity;
int standard_speed;
int counter = 0;
// Wireless settings
const char AUTH[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
const char SSID[] = "mmwireless";
const char PASSWORD[] = "xxxxxxxxxx";
IPAddress mqtt_server(192,168,178,59);
const char* mqtt_username = "mqtt";
const char* mqtt_password = "xxxx";
char* InTopic = "tele/arilux74/STATE"; //subscribe to topic to be notified about
char* InTopic1 = "tele/ESP23/STATE";
WiFiClient espClient;
PubSubClient client(espClient);
Serial.println(F("setup start"));
//Blynk
WiFi.mode(WIFI_STA);
Blynk.begin(AUTH, SSID, PASSWORD,"192.168.178.59",8442);
while (Blynk.connect() == false) { // Wait until connected
if ((millis() - last_UP_change) > 30000) { // 30s before reset
Serial.println(F("resetting"));
ESP.restart();
wait(10);
client.setServer(mqtt_server, 8883);
client.setCallback(callback);
//OTA
// Port defaults to 8266
// ArduinoOTA.setPort(8266);
// Hostname defaults to esp8266-[ChipID]
ArduinoOTA.setHostname("D1-MQTT_Bridge");
// No authentication by default
ArduinoOTA.setPassword((const char *)"xxx");
ArduinoOTA.onStart([]() {
Serial.println("Start");
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
Serial.println(F("Entering loop"));
wait(200);
timer.setInterval(2003L, blinkonoff);
Blynk.virtualWrite(ONOFF_LED,0);
Blynk.virtualWrite(UP_LED,0);
if(!Blynk.connected()) {
Serial.println(F("Resetting in loop"));
ESP.restart();
if (!client.connected()) {
reconnect();
client.loop();
ArduinoOTA.handle();
void wait (int ms) {
long current_time = millis();
long end_time = current_time + ms;
while (current_time < end_time) {
void blinkonoff(){
// Turn runn LED on/off
Blynk.virtualWrite(UP_LED,runn * 255); // turn Up off
runn = !runn;
BLYNK_WRITE(V0) { //ON Off switch
if (param.asInt()) {
client.publish("cmnd/arilux74/power","1");
lamp_on = 1;
else {
client.publish("cmnd/arilux74/power","0");
lamp_on = 0;
Blynk.virtualWrite(ONOFF_LED,lamp_on * 255);
BLYNK_WRITE(V1) { // Dimmer 0-100
brightness = param.asInt();
char bright[4];
dtostrf(brightness, 3, 0, bright);
client.publish("cmnd/arilux74/Dimmer",bright);
BLYNK_WRITE(V2) { // Speed 0-100
standard_speed = param.asInt();
char speed[4];
dtostrf(standard_speed, 3, 0, speed);
client.publish("cmnd/arilux74/speed",speed);
BLYNK_WRITE(V3) { //Color select 0-255 each
char hex[7] = {0};
sprintf(hex,"%02X%02X%02X",param[0].asInt(),param[1].asInt(),param[2].asInt()); //convert to an hexadecimal string. Lookup sprintf for what %02X means.
client.publish("cmnd/arilux74/color",hex);
BLYNK_WRITE(V4) { // Fade switch
if (param.asInt()) client.publish("cmnd/arilux74/fade","1");
else client.publish("cmnd/arilux74/fade","0");
BLYNK_WRITE(V5) { //Scheme slider 0-4
current_activity = param.asInt();
char activity[2];
dtostrf(current_activity, 1, 0, activity);
client.publish("cmnd/arilux74/scheme",activity);
BLYNK_WRITE(V6) { //ON Off upper lights
client.publish("cmnd/ESP23/power","1");
lamp23_on = 1;
else {
client.publish("cmnd/ESP23/power","0");
lamp23_on = 0;
BLYNK_WRITE(V7) { //ON Off lower lights
client.publish("cmnd/ESP24/power","1");
lamp24_on = 1;
else {
client.publish("cmnd/ESP24/power","0");
lamp24_on = 0;
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("BlinkMQTTBridge",mqtt_username,mqtt_password)) {
Serial.println("connected");
counter = 0;
// ... and resubscribe
client.subscribe(InTopic);
client.subscribe(InTopic1);
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 0.3 second");
++counter;
if (counter > 180) ESP.reset();
// Wait .3 seconds before retrying
delay(300);
void callback(char* topic, byte* payload, unsigned int length) {
StaticJsonBuffer<450> jsonBuffer;
//const char* json = "{"Time":"2018-02-09T14:55:30","Uptime":1,"Vcc":3.180,"POWER":"ON","Dimmer":73,"Color":"BA3E00","Scheme":0,"Fade":"OFF","Speed":1,"LedTable":"OFF","Wifi":{"AP":1,"SSId":"mmwireless","RSSI":66,"APMac":"0E:41:58:01:03:F0"}}";
JsonObject& root = jsonBuffer.parseObject((char*)payload);
const char* Time = root["Time"]; // "2018-02-09T14:55:30"
int Uptime = root["Uptime"]; // 1
float Vcc = root["Vcc"]; // 3.18
const char* POWER = root["POWER"]; // "ON"
int Dimmer = root["Dimmer"]; // 73
const char* Color = root["Color"]; // "BA3E00"
int Scheme = root["Scheme"]; // 0
const char* Fade = root["Fade"]; // "OFF"
int Speed = root["Speed"]; // 1
//here you can use this information (optional)
