int sensorData = analogRead(A0); //reading the sensor on A0
int MyValue = map(analogRead(A0), 200, 450, 0, 40);
Blynk.virtualWrite(V5, MyValue); //sending to Blynk
if (MyValue<21)
if (temp==0)
Blynk.logEvent("wtr_lvl_low", "Water Level Low (below 20) in Water Source Location 1 - 26°18' N 89°39' E ") ;
//Blynk.notify ("Water Level Low in Source 1");
Blynk.virtualWrite (V6, HIGH);
temp=1;
else if (MyValue>20){
Blynk.virtualWrite (V6, LOW);
temp=0;
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
pinMode(A0,INPUT);
timer.setInterval(2000L, WaterSensor);
// to avoid delay() function!
void WaterSensor(){
if (MyValue<21)
if (temp==0)
temp=1;
temp=0;
pinMode(A0,INPUT);
Data is coming properly, and V6 is also toggling, but event not being generated.
V6 is going HIGH, temp is defined before this section
#define BLYNK_TEMPLATE_ID "TMPL3GTnnZPX"
#define BLYNK_DEVICE_NAME "Quickstart Device"
#define BLYNK_AUTH_TOKEN "mYcn8BO5amMS_RniijsHyjU1ecBpysn0"
char ssid[] = "dlink-Souvik1";
char pass[] = "12356790";
int temp=0;
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
void WaterSensor(){
if (MyValue<21)
if (temp==0)
temp=1;
temp=0;
pinMode(A0,INPUT);
Then, as @John93 suggested, starting a new “need help with my project” topic is the best approach.
However, if you do start a new topic then include enough information about how each of the event and the corresponding notification tab are configured, what you see in the event timeline, what code you are using etc.
