V6 is going HIGH, temp is defined before this section
#define BLYNK_TEMPLATE_ID "TMPL3GTnnZPX"
#define BLYNK_DEVICE_NAME "Quickstart Device"
#define BLYNK_AUTH_TOKEN "mYcn8BO5amMS_RniijsHyjU1ecBpysn0"
char ssid[] = "dlink-Souvik1";
char pass[] = "12356790";
int temp=0;
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
void WaterSensor(){
int sensorData = analogRead(A0); //reading the sensor on A0
int MyValue = map(analogRead(A0), 200, 450, 0, 40);
Blynk.virtualWrite(V5, MyValue); //sending to Blynk
if (MyValue<21)
if (temp==0)
Blynk.logEvent("wtr_lvl_low", "Water Level Low (below 20) in Water Source Location 1 - 26°18' N 89°39' E ") ;
//Blynk.notify ("Water Level Low in Source 1");
Blynk.virtualWrite (V6, HIGH);
temp=1;
else if (MyValue>20){
Blynk.virtualWrite (V6, LOW);
temp=0;
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
pinMode(A0,INPUT);
timer.setInterval(2000L, WaterSensor);
// to avoid delay() function!
