In this release
New features:
Update to Arduino IDE 1.8.0
Add Check for updates to Tools menu [beta]
Add Run USB script to Tools menu [beta]
BLYNK_APP_CONNECTED() support (will be available soon)
Add .config() support for Particle
Bugs fixed:
Fix syncVirtual with multiple pins
Improved GSM/GPRS support
Fix virtualWrite issue with F() strings
Travis CI updated
Grab the latest version here: https://github.com/blynkkk/blynk-library/releases/latest
And don’t forget to give us a star on github
Please post here your feedback about this release. Thank you!
wanek
December 26, 2016, 8:13pm
3
what are these mean?
should i have them in the tools menu?
yes, after you install latest library
wanek
December 26, 2016, 8:17pm
5
the 1.8.0 ide i have clean installed some days ago.
the library clean installed right now (copied all the folders from the zip file in the arduino lib folder)
restarted the ide
but these new entries won’t show up in the tools menu…
or i do not understand how should i do.
wanek
December 26, 2016, 8:20pm
7
but, anyway, what are these new functions should do?
didn’t we already got updates regarding the blynk lib via the built in lib manager?
Brummer
December 26, 2016, 8:32pm
8
I updated to Arduino IDE 1.8.0 and Blynk v0.4.3
Also I copied the folders to the library
When I open my Arduino IDE than I get a error message:
Invalid library found in C:\Users\xxx\Documents\Arduino\libraries\tools:
How can I correct this ?
What´s wrong?
wanek
December 26, 2016, 8:46pm
9
if you want a quick temporary solution, just try to delete the tools folder from the arduino libraries folder.
Brummer
December 26, 2016, 8:49pm
10
Thank you, that what I´m thinking also.
But it contains the blynk updater and I´m expecting that this will be need ?
It should be one of the new features ? right?
wanek
December 26, 2016, 8:51pm
11
yes, but i mean you can just delete it, until the problem will be solved, if you need to use the ide.
Brummer
December 26, 2016, 8:53pm
12
Thank you I hope that one of the founders will read this and solve the issue.
Ok, sorry guys - it is not that easy.
I just updated the release zip file, so just reinstall it.
The tools will not be available - I will post here when I add them back again.
Brummer
December 26, 2016, 9:58pm
14
Must I change all folders or is it sufficient to delete the tools folder ?
yes, tools was just in wrong place, but this impacts also some code, so tools will be updated.
just remove tools for now
Sorry for inconvenience!
I put the tools back into the package.
If you want to give them a try, please download latest release zip from https://github.com/blynkkk/blynk-library/releases/latest
@Brummer , @wanek
Blynk library contains multiple libraries, so it is easier to update through the tool menu.
Costas
December 27, 2016, 12:44pm
18
Is this just for the 1 main Blynk library or for all 6 libraries?
It updates the whole release package.
You will see the process once the library gets updated once again.
wanek
December 27, 2016, 3:43pm
20
…any info about the “run usb script” function?
