Hi, i am using Arduino Mega 2560 with ESP8266 on a local server. Tried running the code below and my Blynk will disconnect. Is it because of flooding? BTW i tried running the functions separately and it works fine but when i compile them into a single code they do not work. Can someone please help me
#include <ESP8266_Lib.h>
#include <Blynk.h>
#include "DHT.h"
SoftwareSerial EspSerial(10, 11); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
#define DHTPIN 11
#define DHTTYPE DHT11 // DHT 22 (AM2302), AM2321
DHT dht(DHTPIN, DHTTYPE);
ESP8266 wifi(&EspSerial);
int PWM = 3;
boolean running_two = false;
int takeover2 = 0;
char auth[] = "***";
char ssid[] = "**";
char pass[] = "**";
//dht and fan
WidgetLED led3(V3);
BLYNK_WRITE(V3)
int value = param.asInt();
digitalWrite(12,value);
if (value == LOW){
led3.off();
Serial.println("AC OFF");
led3.on();
Serial.println("AC ON");
void tempsensor(){
running_two = takeover2;
float h = dht.readHumidity();
Blynk.virtualWrite(V4, t);
Blynk.virtualWrite(V5, h);
if (t > 35 && running_two == false){
digitalWrite(PWM, HIGH);
else if (t < 35 && running_two == false) {
digitalWrite(PWM, LOW);
BLYNK_WRITE(V6) // Button Widget is writing to pin V1
int fanSpeed = param.asInt();
if (fanSpeed == 0) {
analogWrite(PWM, 0);
Serial.println("FAN OFF");
} else if (fanSpeed == 1) {
analogWrite(PWM, 190);
Serial.println("LOW");
}else if (fanSpeed == 2) {
analogWrite(PWM, 255);
Serial.println("HIGH");
BLYNK_WRITE(V7) {
takeover2 = param.asInt();
if (takeover2 == HIGH){
running_two == true;
Serial.println("takeover fan");
else if (takeover2 == LOW) {
running_two == false;
Serial.println("back to DHT11");
return running_two;
//ldr
const int ledPin = 13; //the number of the LED pin
const int ldrPin = A0; //the number of the LDR pin
int val = 0;
int takeover = 0;
int relay1State = 0;
boolean running = false; //
BLYNK_WRITE(V2) {
relay1State = param.asInt();
digitalWrite(ledPin, relay1State);
BLYNK_WRITE(V1) {
takeover = param.asInt();
if (takeover == HIGH){
running == true;
Serial.println("taken over");
else if (takeover == LOW) {
running == false;
Serial.println("back to LDR sensor");
return running;
void checkLDR() {
int relay1Status = digitalRead(ledPin);
int ldrStatus = analogRead(ldrPin); //read the status of the LDR value
running = takeover;
//check if the LDR status is <= 300
//if it is, the LED is HIGH
if (ldrStatus <=300 && running == false) {
digitalWrite(ledPin, HIGH); //turn LED on
Serial.println("Light Bulb is ON");
Blynk.virtualWrite(V1, relay1Status);
else if (ldrStatus >=300 && running == false ){
digitalWrite(ledPin, LOW); //turn LED off
Serial.println("Light Bulb is OFF");
// Update Button Widget
//Setup
void setup() { // the setup function runs once when you press reset or power the board
// Set ESP8266 baud rate
Blynk.begin(auth, wifi, ssid, pass, "***", 8080);
//lights
pinMode(ledPin, OUTPUT); //initialize the LED pin as an output
pinMode(ldrPin, INPUT); //initialize the LDR pin as an input
timer.setInterval(4000L, checkLDR);
pinMode(12,OUTPUT);
dht.begin();
pinMode(PWM,OUTPUT);
timer.setInterval(2000L, tempsensor);
