Hi, i am using Arduino Mega 2560 to read temperature and humidity value from my DHT11 sensor and display it on the BLYNK app. The sensor values can be displayed in Arduino Serial Monitor but cannot display inside BLYNK. Blynk will disconnect and i don’t know why. Tried run other programs using BLYNK and it works just fine so there must be something wrong with this coding. BTW i tot this coding from the Blynk examples. Can someone please help me?
#include <ESP8266_Lib.h>
#include <Blynk.h>
#include "DHT.h"
SoftwareSerial EspSerial(10, 11); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
#define DHTPIN 11
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
ESP8266 wifi(&EspSerial);
char auth[] = "***************";
char ssid[] = "*******";
char pass[] = "*****";
//#define EspSerial Serial1
float h =0;
float t =0;
//Fan Part
WidgetLED led3(V3);
BLYNK_WRITE(V3)
// You'll get HIGH/1 at startTime and LOW/0 at stopTime.
// this method will be triggered every day
// until you remove widget or stop project or
// clean stop/start fields of widget
int value = param.asInt();
digitalWrite(12,value);
if (value == LOW){
led3.off();
Serial.println("AC OFF");
led3.on();
Serial.println("AC ON");
void tempsensor(){
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
Serial.println(h);
// Read temperature as Celsius (the default)
Serial.println(t);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) ) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
Blynk.virtualWrite(V4, t);
Blynk.virtualWrite(V5, h);
//Setup
void setup() { // the setup function runs once when you press reset or power the board
// Set ESP8266 baud rate
dht.begin();
timer.setInterval(1000L, tempsensor);
//tempsensor();
The only thing I can really see is that you are using the same pin for you ESPSerial connection, and for your DHT11. Maybe try putting the DHT11 on a different pin.
Yes, but if you go back to the original Sketch Builder example you’ll see that it says to use hardware serial for the Mega, but you’ve gone down the route of using Software Serial and you’ve changed the pins from 2 & 3 to 10 & 11 - which as @Toro_Blanco has pointed-out means that pin 10 is being used for two connections, which will never work.
Hi, i am using Arduino Mega 2560 with ESP8266 on a local server. Tried running the code below and my Blynk will disconnect. Is it because of flooding? BTW i tried running the functions separately and it works fine but when i compile them into a single code they do not work. Can someone please help me
#include <Blynk.h>
#include "DHT.h"
#define DHTPIN 11
#define DHTTYPE DHT11 // DHT 22 (AM2302), AM2321
int PWM = 3;
boolean running_two = false;
int takeover2 = 0;
char auth[] = "***";
char ssid[] = "**";
char pass[] = "**";
//dht and fan
WidgetLED led3(V3);
BLYNK_WRITE(V3)
if (value == LOW){
led3.off();
led3.on();
void tempsensor(){
running_two = takeover2;
if (t > 35 && running_two == false){
digitalWrite(PWM, HIGH);
else if (t < 35 && running_two == false) {
digitalWrite(PWM, LOW);
BLYNK_WRITE(V6) // Button Widget is writing to pin V1
int fanSpeed = param.asInt();
if (fanSpeed == 0) {
analogWrite(PWM, 0);
Serial.println("FAN OFF");
} else if (fanSpeed == 1) {
analogWrite(PWM, 190);
Serial.println("LOW");
}else if (fanSpeed == 2) {
analogWrite(PWM, 255);
Serial.println("HIGH");
BLYNK_WRITE(V7) {
takeover2 = param.asInt();
if (takeover2 == HIGH){
running_two == true;
Serial.println("takeover fan");
else if (takeover2 == LOW) {
running_two == false;
Serial.println("back to DHT11");
return running_two;
//ldr
const int ledPin = 13; //the number of the LED pin
const int ldrPin = A0; //the number of the LDR pin
int val = 0;
int takeover = 0;
int relay1State = 0;
boolean running = false; //
BLYNK_WRITE(V2) {
relay1State = param.asInt();
digitalWrite(ledPin, relay1State);
BLYNK_WRITE(V1) {
takeover = param.asInt();
if (takeover == HIGH){
running == true;
Serial.println("taken over");
else if (takeover == LOW) {
running == false;
Serial.println("back to LDR sensor");
return running;
void checkLDR() {
int relay1Status = digitalRead(ledPin);
int ldrStatus = analogRead(ldrPin); //read the status of the LDR value
running = takeover;
//check if the LDR status is <= 300
//if it is, the LED is HIGH
if (ldrStatus <=300 && running == false) {
digitalWrite(ledPin, HIGH); //turn LED on
Serial.println("Light Bulb is ON");
Blynk.virtualWrite(V1, relay1Status);
else if (ldrStatus >=300 && running == false ){
digitalWrite(ledPin, LOW); //turn LED off
Serial.println("Light Bulb is OFF");
// Update Button Widget
//Setup
Blynk.begin(auth, wifi, ssid, pass, "***", 8080);
//lights
pinMode(ledPin, OUTPUT); //initialize the LED pin as an output
pinMode(ldrPin, INPUT); //initialize the LDR pin as an input
timer.setInterval(4000L, checkLDR);
pinMode(12,OUTPUT);
dht.begin();
pinMode(PWM,OUTPUT);
timer.setInterval(2000L, tempsensor);
@m9506 I’ve merged your new topic into your previous one.
The answer is the same, you can’t use Pin 11 for both your DHT sensor and Software Serial.
You have a Mega, which has 3 serial ports, so you shouldn’t be using SoftwareSerial anyway.
Please don’t keep creating new topics about the same issue, especially when the problem has been answered already.
