Hello
I am new to programming, and I would like your help.
I have been working here for a long time on the following sketch
This is a simple demo of sending and receiving some data.
Be sure to check out other examples!
//define BLYNK_TEMPLATE_ID "TMPLW********"
//#define BLYNK_DEVICE_NAME "home alarm *******"
//#define BLYNK_AUTH_TOKEN "SO1_2ZyDcAl*******************"
#define BLYNK_TEMPLATE_ID "TMP*********"
#define BLYNK_DEVICE_NAME "SI***********"
#define BLYNK_AUTH_TOKEN "n6lNJ********************"
//char ssid[] = "TP-LINK_GP";
char ssid[] = "TP-LINK@GP";
char pass[] = "7************";
bool alarm_mode = false ;
bool sensorf = false ;
//int alarm_led = 9;
int sensor = 5; //GPIO Pin number on which sensor is connected
int sensor_1 = 13; //GPIO Pin number on which sensor is connected
int buzzer = 15; //GPIO Pin number on which buzzer is connecte
int pir_sensor = 14; //GPIO Pin number on which sensor is connected
int pir_sensor1 = 16; //GPIO Pin number on which sensor is connected
int pir_sensor2 = 12; //GPIO Pin number on which sensor is connected
int pir_sensor3 = 10;
int pin_onoff = 4;
void myTimerEvent(){
if(digitalRead(sensor) == 0){
Blynk.virtualWrite(V0, "ΣΕΙΡΗΝΑ ΑΝΕΝΕΡΓΗ");}
if(digitalRead(sensor_1) == 1){
Blynk.virtualWrite(V2, "ΣΥΣΤΗΜΑ ΟΠΛΙΣΜΕΝΟ");}
if(digitalRead(pir_sensor1) == 0){
Blynk.virtualWrite(V3, "CLOSE");}
if(digitalRead(pir_sensor2) == 0){
Blynk.virtualWrite(V4, "CLOSE");}
if(digitalRead(pir_sensor) == 0){
Blynk.virtualWrite(V5, "CLOSE");}
if(digitalRead(pir_sensor3) == 0){
Blynk.virtualWrite(V6, "CLOSE");}
if(digitalRead(sensor) == 1){
Blynk.virtualWrite(V0, "ΣΕΙΡΗΝΑ ΕΝΕΡΓΗ");
if(alarm_mode == true){
Blynk.notify("ΠΡΟΣΟΧΗ!!! Η ΣΕΙΡΗΝΑ ΧΤΥΠΑ");
digitalWrite(buzzer, HIGH);
if(digitalRead(sensor_1) == 0){
Blynk.virtualWrite(V2, "ΣΥΣΤΗΜΑ ΑΦΟΠΛΙΣΜΕΝΟ");
Blynk.notify("ΠΡΟΣΟΧΗ!!! ΤΟ ΣΥΣΤΗΜΑ ΕΙΝΑΙ ΑΦΟΠΛΙΣΜΕΝΟ");
digitalWrite(buzzer,HIGH);
if(digitalRead(pir_sensor1) == 1){
Blynk.virtualWrite(V3, "OPEN");
if(alarm_mode == true && sensorf == false){
Blynk.notify("ALERT,radar apothikh is open,Alarm Mode ON");
if(digitalRead(pir_sensor3) == 1){
Blynk.virtualWrite(V6, "OPEN");
Blynk.notify("ALERT,RADAR KREBATOKAMARA IS OPEN,ALARM MODE ON");
if(digitalRead(pir_sensor2) == 1){
Blynk.virtualWrite(V4, "OPEN");
Blynk.notify("ALERT,radar paidiko is open,Alarm Mode ON");
if(digitalRead(pir_sensor) == 1){
Blynk.virtualWrite(V5, "OPEN");
Blynk.notify("ALERT,radar saloni is open,Alarm Mode ON");
BLYNK_WRITE(V1) {
switch (param.asInt()) {
case 1: { // Item 1
Serial.println("Item 1 selected");
alarm_mode = true;
sensorf = false;
//digitalWrite(alarm_led, HIGH);
break;
case 4: { // Item 4
Serial.println("Item 4 selected");
alarm_mode = true;
sensorf =true;
digitalWrite(sensor, HIGH);
//digitalWrite(alarm_led, LOW);
break;
case 2: { // Item 2
Serial.println("Item 2 selected");
alarm_mode = false;
sensorf = false;
digitalWrite(buzzer, LOW);
// digitalWrite(alarm_led, LOW);
break;
case 3: { // Item 3
Serial.println("Item 3 selected");
alarm_mode = false;
sensorf = false;
break;
//case 5: { // Item 5
// Serial.println("Item 5 selected");
//alarm_mode = false;
//sensorf = false;
//digitalWrite(4,HIGH);
//digitalWrite(pin_onoff, HIGH); // δοκιμασε το και αναποδα
//delay(200);
//digitalWrite(pin_onoff, LOW);
//pinMode(pin_onoff,OUTPUT);
//break;
BLYNK_CONNECTED(){
Blynk.syncAll();
pinMode(sensor,INPUT_PULLUP);
pinMode(buzzer,OUTPUT);
// pinMode(alarm_led,INPUT_PULLUP);
pinMode(pir_sensor,INPUT_PULLUP);
pinMode(sensor_1,INPUT_PULLUP);
pinMode(pir_sensor1,INPUT_PULLUP);
pinMode(pir_sensor2,INPUT_PULLUP);
pinMode(pir_sensor3,INPUT_PULLUP);
digitalWrite(4,LOW);
//timer.setInterval(500L, myTimerEvent);
with the previous version, I had notifications on my phone normally,
now i can’t make it.
I want to have notifications about the following
(“ΠΡΟΣΟΧΗ!!! ΤΟ ΣΥΣΤΗΜΑ ΕΙΝΑΙ ΑΦΟΠΛΙΣΜΕΝΟ”)
and
I have created an account,tamplate,event,datastreams and automations
