Tried making some changes on the mobile dashboard and got a pop-up that I don’t have enough energy to add more widgets. Even tried deleting a couple, still not enough energy. Can’t see how much I have or how much widgets use.
It depends on what plan do you have,
Free plan 30 widgets per template per device.
Plus plan 80 widgets per template per device.
Pro plan 255 widgets per template per device.
John was correct, I had exceeded the widget limit. (Not sure how I got past the limit previously; I had to delete a handful of Labeled Values to be able to add 1 Slider)
We found a place where it shows something similar to the old code message - we will fix it. Looks like you have reached your plan limit for widgets amount in the template
