BLYNK
Blynk controlled DPS5005
Hallo Blynker
my project is Blynk controlled DPS5005 with Modbus :cool:
We can :
1-Set V
2-Set A
3-ON OFF
4-Reading Volt Amber Watt
5-Temperature inside the box in C
6- History Chart
we need
1-Esp32 Devbord
2- DPS5005 50V 5A Communication Function
3-Mini Micro JST GH1.25mm 4pin you can use module cabel if you want
4-LM2596S-ADJ Adjustable DC-DC Power Module to power ESP32 from input Voltage
Video:
schematic:
TX DPS5005 To RX0 in ESP32
RX DPS5005 To TX0 in ESP32
sorry for all photos in one upload (new users Limitation):hushed:
code:
         // DPS5005 with Blynk By Hussein Daj(www.hussein-solutions.de)
        // Credit to Luke (www.ls-homeprojects.co.uk)
        // Free to use this code how you like but please link my site
        // Credit to Doc Walker of ModbusMaster for making a great Arduino Library https://github.com/4-20ma/ModbusMaster
        //Built-in Temperature sensor حساس الحرارة الداخلي ضمن الكنتورلر
        #ifdef __cplusplus
        extern "C" {
        #endif
        uint8_t temprature_sens_read();
        #ifdef __cplusplus
        #endif
        #include <ModbusMaster.h> // ModbusMaster
        #include <WiFi.h>
        #include <WiFiClient.h>
        #include <BlynkSimpleEsp32.h>
        ModbusMaster node;    // instantiate ModbusMaster object
        float voltage = 0.0;
        float current = 0.0;
        float power = 0.0;
        float SetV = 0;
        float SetA = 0;
        bool on=0;
        char auth[] = "blynk code"; //الكود الخاص بمشروع بلنك
        char ssid[] = "your ssid";//اسم شبكة الواير ليس
        char pass[] = "ssid password";//كلمة السر
        void myTimerEvent()
           Read();
          Blynk.virtualWrite(V0,voltage); //out V
          Blynk.virtualWrite(V1,current); //out A
          Blynk.virtualWrite(V9,SetV); //SetV
          Blynk.virtualWrite(V8,SetA); //SetA
          Blynk.virtualWrite(V5,on); //on off state
          Blynk.virtualWrite(V2,power); //on off state
          int Temp=((temprature_sens_read() - 32 ) / 1.8);
          Blynk.virtualWrite(V3,Temp);
          node.begin(1,Serial);
        //Read Data
        void Read(){
           uint8_t j, result;
            result = node.readHoldingRegisters(0, 10);  // slave: read a range of 16-bit registers starting at register 0 to 10
         if (result == node.ku8MBSuccess)   // only do something with data if read is successful
           voltage =  ((float)node.getResponseBuffer(2) / 100 ); // get voltage from response buffer and convert to float
          current =  ((float)node.getResponseBuffer(3) / 1000 ); // get current from response buffer and convert to float
          power =  ((float)node.getResponseBuffer(4) / 100 ); // get power from response buffer and convert to float
           SetV =  ((float)node.getResponseBuffer(0) / 100 ); // get SetV from response buffer and convert to float
           SetA =  ((float)node.getResponseBuffer(1) / 1000 ); // get SetA from response buffer and convert to float
              on =  ((bool)node.getResponseBuffer(9) ); // Status on or off
        //Write Data
        BLYNK_WRITE(V5) //on off
          int pinValue = param.asInt(); // assigning incoming value from pin V5 to a variable
           node.writeSingleRegister(9, pinValue); //set power on !
        BLYNK_WRITE(V6) //Set V
          int pinValue = param.asFloat(); // assigning incoming value from pin V5 to a variable
          node.writeSingleRegister(0, pinValue*10);
        BLYNK_WRITE(V7) //Set A
        node.writeSingleRegister(1, pinValue*100);
Blynk:
http://tinyurl.com/y8m6aywx
Very nice Project for the popular Bench power supply , and more nice to see more Arabs are going into such technology i have cached your Arabic comments in the project code.
greetings from EGYPT.
Hi, I have tested the project with a DPS3005, but I can not get it to work.
Could you explain a bit how to configure blynk virtual ports and the selection of volts and amps?
I only get temperature data, but my dps I think it has no temperature …
Hallo @emi2
temperature data from ESP32 not from DPS3005
are you sure Serial between ESP32 and DSP is
TX ---- >RX
RX------>TX
and GND in ESP with GND in DPS3005 :eyeglasses:
i check DPS3005 is the same DPS5005 Buffer
so it the same code for more deltils you can read communication protocol for this device is specifically MODBUS RTU
http://www.mediafire.com/file/8qq84gdemedde6j/DPS3005_CNC_Communication__Protocol_V1.2.docx
greetings
Thank you very much, sometimes you look 100 times and you do not see it …
It works for me. A very good code.
greetings
Hi Hussein
thanks for your great project.
I have a pb the link to the blink does not work: http://tinyurl.com/y8m6aywx
Would you please check or do I make a mistake?
thanks
@Dx266
it is work
you must open it from your mobile browser
Best regards
Thanks Hussein for your help. One more question: how many credits is required for your blynk app?
thanks a lot
@Dx266
2700 credits
but you can delet chart so you save 900 credits
regards
Thanks very much Hussein.
can I ask you a favor? Would you mind saving your project without the charts? You cannot even open it on the free version (2000credits) to modify it and I cannot buy credit with my pro phone… Again thanks a lot.
you don,t need to copy my project
create new one and use same virtual pin like this photo and chose what you want
Hello, does it also work on a ESP8266?
I tried it with your code and a example blynk, but in my way it desn’t
thanks a lot so far for your work.
Hello, I have adapted it for ESP8266 - Wemos D1 mini, because it is smaller and cheaper. For the temperature I use a DHT11.
I have also added the update by OTA.
This is the modified code:
        // Credit to Luke 8)
        #include <ArduinoOTA.h>
        #include <SoftwareSerial.h> // Software Serial Library so we can use other Pins for communication with DPS5005 module
        #include <DHT.h>
        #define DHTPIN D4     // what digital pin we're connected to pin 2
        #define DHTTYPE DHT11   // DHT 11
        DHT dht(DHTPIN, DHTTYPE);
        static const int RXPin = D6, TXPin = D7;             // DPMS3005 module to pins 4 and 3 ESP8266
        SoftwareSerial ss(RXPin, TXPin);                     // The serial connection to the DPS3005 device
        float power = 0.0;
        float SetV = 0;
        float SetA = 0;
        bool on=0;
        void myTimerEvent()
           Read();
          //float t = dht.readTemperature(true); // Read temperature as Fahrenheit (isFahrenheit = true)
          float t = dht.readTemperature(); // Read temperature as Celsius (the default)
          Blynk.virtualWrite(V3,t);
          WiFi.mode(WIFI_STA);
          dht.begin();
          ss.begin(9600);           // Set Software Serial Comm Speed to 9600
          node.begin(1,ss);
          while (Blynk.connect() == false) {}
          ArduinoOTA.setHostname("DPS5005"); // OPTIONAL NAME FOR OTA
          ArduinoOTA.begin();
          ArduinoOTA.handle();
        //Read Data
        void Read(){
           uint8_t j, result;
        //Write Data
That’s how I got it, I’m fear of the slider and voltage.
@emi2 very nice work and thanks for your reply
but which pins do you connect the RX and TX from the module? to D6 and D7 or to TX RX or GPIO3/4 on the esp8266
thanks a lot
Hello, in the forums I read that in the ESP8266 the TX and the RX give problems, so I use the softwareserial to choose other pins.
The pins I use are RXPin = D6, TXPin = D7 using Wemos D1 mini in the Arduino IDE.
What kind of problems? :face_with_raised_eyebrow:
Actually, I don’t remember well, I think there were communication problems when using the rx tx and the usb serial monitor of the Wemos. But I have not checked it.
Anyway, I made the work easy, copy the configuration from other projects to communicate with DPS5005.
Surely it can be simplified by removing SoftwareSerial and using rx tx, since the usb is not used here.
Ah, yes! but only when it’s serial port is actively occupied by another node! It is the same as with UNO.
