Hi, yesterday my esp8266 failed me. After checking everything, I discovered that it failed in the “Adafruit_BMP085.h” library.
I replaced the library with “SFE_BMP180.h” and now it works correctly.
I have marked the lines of the BMP180, in case the error returned, for eliminate them easily.
I have also added V4 for see input voltage, just like on the screen.
I’m sorry I took so long to give a solution.
// DPS5005 with Blynk By Hussein Daj(www.hussein-solutions.de)
// Credit to Luke 8)
// Free to use this code how you like but please link my site
// Credit to Doc Walker of ModbusMaster for making a great Arduino Library https://github.com/4-20ma/ModbusMaster
#include <ArduinoOTA.h>
#include <ModbusMaster.h> // ModbusMaster
#include <SFE_BMP180.h> //BMP180
SFE_BMP180 temp; // BMP180 I2C D1 D2
String myHostname = "DPS5005"; // Name for Host in the Network
ModbusMaster node; // instantiate ModbusMaster object
float voltage = 0.0;
float current = 0.0;
float power = 0.0;
float vin = 0.0;
float SetV = 0;
float SetA = 0;
bool on=0;
char auth[] = "blynk code"; //الكود الخاص بمشروع بلنك
char ssid[] = "your ssid";//اسم شبكة الواير ليس
char pass[] = "ssid password";//كلمة السر
char status; //BMP180
double T; //BMP180
void myTimerEvent()
Read();
Blynk.virtualWrite(V0,voltage); //out V
Blynk.virtualWrite(V1,current); //out A
Blynk.virtualWrite(V4,vin); //in V --> New
Blynk.virtualWrite(V9,SetV); //SetV
Blynk.virtualWrite(V8,SetA); //SetA
Blynk.virtualWrite(V5,on); //on off state
Blynk.virtualWrite(V2,power); //on off state
Blynk.virtualWrite(V3, T);
WiFi.mode(WIFI_STA);
WiFi.hostname(myHostname);
temp.begin(); //BMP180
node.begin(1,Serial);
while (Blynk.connect() == false) {}
ArduinoOTA.setHostname("DPS5005"); // OPTIONAL NAME
ArduinoOTA.begin();
ArduinoOTA.handle();
status = temp.startTemperature(); //BMP180
status = temp.getTemperature(T); //BMP180
//Read Data
void Read(){
uint8_t j, result;
result = node.readHoldingRegisters(0, 10); // slave: read a range of 16-bit registers starting at register 0 to 10
if (result == node.ku8MBSuccess) // only do something with data if read is successful
voltage = ((float)node.getResponseBuffer(2) / 100 ); // get voltage from response buffer and convert to float
current = ((float)node.getResponseBuffer(3) / 1000 ); // get current from response buffer and convert to float
power = ((float)node.getResponseBuffer(4) / 100 ); // get power from response buffer and convert to float
vin = ((float)node.getResponseBuffer(5) / 100 ); // get in voltage from response buffer and convert to float ---> Input Voltage
SetV = ((float)node.getResponseBuffer(0) / 100 ); // get SetV from response buffer and convert to float
SetA = ((float)node.getResponseBuffer(1) / 1000 ); // get SetA from response buffer and convert to float
on = ((bool)node.getResponseBuffer(9) ); // Status on or off
//Write Data
BLYNK_WRITE(V5) //on off
int pinValue = param.asInt(); // assigning incoming value from pin V5 to a variable
node.writeSingleRegister(9, pinValue); //set power on !
BLYNK_WRITE(V6) //Set V
int pinValue = param.asFloat(); // assigning incoming value from pin V5 to a variable
node.writeSingleRegister(0, pinValue*10);
BLYNK_WRITE(V7) //Set A
node.writeSingleRegister(1, pinValue*100);
}</code></pre>
