Blynk Connection to WPA2 EAP Networks
I am using Blynk in combination with an Arduino Mega and an ESP8266. After some tests, it was rather easy to get connected to my home network, being secured with WPA2 PSK. The problem is, this setup should also work with the university WLAN, being an WPA2 EAP network. The ESP8266 supports this since SDK 1.5, but Blynk only works stable with SDK 1.0 v22 as far as I know. So, does anyone know how to connect to an EAP network with Blynk? Doesn’t have to be with an ESP8266, but it would be good if it would be with that module.
Thanks in advance!
Can you send us some code that works on ESP8266 and your network (without Blynk)?
Hi vhymanskyy,
I don’t know if the original poster sent you code that works without blynk, but I can. This code works with the Blynk stuff commented out as shown, but it crashes with a <<<stack<<< with it.
   #include <Arduino.h>
        Follow us:                  http://www.fb.com/blynkapp
                                    http://twitter.com/blynk_app
      You’ll need:
       - Blynk App (download from AppStore or Google Play)
       - ESP8266 board
      started. Think of them as LEGO bricks  and combine them as you wish.
      example.
    //#define BLYNK_PRINT Serial
    //#include <BlynkSimpleEsp8266_SSL.h>
    extern "C" {
    #include "user_interface.h"
    #include "wpa2_enterprise.h"
    char auth[] = "my_auth_token";
    // SSID to connect to
    static const char* ssid = "my_ssid";
    // Username for authentification
    static const char* username = "my_userid";
    // Password for authentication
    static const char* password = "my_passwd";
      // Setting ESP into STATION mode only (no AP mode or dual mode)
      wifi_set_opmode(STATION_MODE);
      struct station_config wifi_config;
      memset(&wifi_config, 0, sizeof(wifi_config));
      strcpy((char*)wifi_config.ssid, ssid);
      wifi_station_set_config(&wifi_config);
      wifi_station_clear_cert_key();
      wifi_station_clear_enterprise_ca_cert();
      wifi_station_set_wpa2_enterprise_auth(1);
      wifi_station_set_enterprise_identity((uint8*)username, strlen(username));
      wifi_station_set_enterprise_username((uint8*)username, strlen(username));
      wifi_station_set_enterprise_password((uint8*)password, strlen(password));
      //wifi_station_connect(); // Commented out with blynk.
      //Blynk.begin(auth, ssid, password);
      // Wait for connection AND IP address from DHCP
      Serial.println();
      Serial.println("Waiting for connection and IP Address from DHCP");
      delay(2000);
      Serial.print(".");
      Serial.println("");
      Serial.println("IP address: ");
      //Blynk.run();
      Serial.println("In main loop...");
      // to avoid delay() function!
You obviously have to include your ssid, username and password, and have a WPA2 Enterprise network. Ours is using PEAP.
Thanks,
Rob
Hi guys…
Is there any news on having WPA2 EAP for blynk @vshymanskyy?
This is a very old topic… Now we can use Blynk.config() as that will allow you to use whatever WiFi setup you need, prior to connecting to Blynk’s server.
http://docs.blynk.cc/#blynk-firmware-configuration-blynkconfig
FYI, no need to tag a developer that is already in the topic.
Hi @Gunner , i need help on esp32 with wpa2 peap enterprise wifi connect to the blynk. I manage to connect wifi with my esp32 module but it does not work for blynk web application.
Same answers as previously - this is a very old topic, you’d be better starting a new one.
Post your code that DOES work with this network, and your Blynk code that doesn’t work.
Don’t forget to include answers to all of the questions that you are asked when you create a new “Need help with my project” topic, take note of the information about how to correctly format your code when you post it, apply the same formatting when you post your serial monitor output (which will be useful in this situation. Don’t post screenshots of code or serial output.
Be clear about whether you are using Blynk Legacy or Blynk IoT.
BTW, @Gunner isn’t a regular on this forum anymore, I’m probably the 2nd best alternative.
In the meantime, I’m closing this 6 year old topic.
