Hello everyone, sorry for my english …
Please can someone help me with Blynk, Arduino Mega and 433 MHz transmitter?
I would like to use Arduino Mega with transmitter to send the codes in RF 433 Mhz and some Arduino Nano with 433 MHz RF receiver that, according to the code received, turn on and off the relays …
Can someone help me with Blynk?
Thanks so much.
you need to be a bit more specific than that:
What do you have already coded (pls share)?
With what do you exactly need help?
What is the blynk part of your project?
Thanks for your interest…
I can not create the part that sends the codes … for example:
If I send the code 1755 it turns on the light of the room 1
if I send the code 1756 it turns off the light of the room 1
if I send the code 1888 the boiler is turned on
if I send the code 1889 the boiler is turned off …
thank you.
/*************** 433Mhz Settings ***************/
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
#define PACKET_LENGTH 24 //length
#define SWITCH_1_ON 1755 // decimal code
#define SWITCH_1_OFF 1756
#define SWITCH_2_ON 1888
#define SWITCH_2_OFF 1889
int BTN1;
int BTN2;
BLYNK_WRITE(V1) {
BTN1 = param.asInt();
if (BTN1 == true) {
mySwitch.send(SWITCH_1_ON, PACKET_LENGTH);
else {
mySwitch.send(SWITCH_1_OFF, PACKET_LENGTH);
BLYNK_WRITE(V2) {
BTN2 = param.asInt();
if (BTN2 == true) {
mySwitch.send(SWITCH_2_ON, PACKET_LENGTH);
else {
mySwitch.send(SWITCH_2_OFF, PACKET_LENGTH);
Thanks Alexis, great …
Now I have two arduino nano, the first controls the light of camera 1 and the second commands the caladia, both have a 433 MHz RF receiver, according to the code launched by the transmitter they must be able to reset the digital pin 2 or 3 … .
Thank you
thank you very much for the help you gave me …
But how do I make Arduino and Blynk understand that the 433MHz RF is connected to the digital 4 pin?
Thank you
hello !
this is the code
/* ARDUINO NODEMCU
0 D3
1 D10
2 D4
3 D9
4 D2
5 D1
12 D6
13 D7
14 D5
15 D8
16 DO */
mySwitch.enableTransmit(4); //nodemcu D2
Thanks, it gives me error "exit status 1 ‘mySwitch’ does not name a type
What does it mean?
don’t forget to declare that
I declared it
but still gives me the error …
Help me, please …
please post your entire code, I will take a look.
don’t forget to format it.
nervimarco:
I declared it
‘RCSwitch’ does not name a type
error: ‘mySwitch’ was not declared in this scope
this is the issue when I comment :
//#include <RCSwitch.h>
so, you have not the RCSwitch.h library , or you made a mistake naming your lib
#include <Ethernet.h>
#include <DHT.h>
#define SWITCH_1_ON 1173 // decimal code
#define SWITCH_1_OFF 1179
#define SWITCH_2_ON 1273
#define SWITCH_2_OFF 1279
#define SWITCH_3_ON 1373 // decimal code
#define SWITCH_3_OFF 1379
#define SWITCH_4_ON 1473
#define SWITCH_4_OFF 1479
#define SWITCH_5_ON 1573 // decimal code
#define SWITCH_5_OFF 1579
#define SWITCH_6_ON 1673
#define SWITCH_6_OFF 1679
int BTN1;
int BTN2;
int BTN3;
int BTN4;
int BTN5;
int BTN6;
char auth[] = "token";
#define W5100_CS 10
#define SDCARD_CS 4
#define DHT1PIN 2 // What digital pin we're connected to
#define DHT2PIN 3 // What digital pin we're connected to
#define DHT1TYPE DHT11 // DHT 11
#define DHT2TYPE DHT11 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht1(DHT1PIN, DHT1TYPE);
DHT dht2(DHT2PIN, DHT2TYPE);
void sendSensor()
float h1 = dht1.readHumidity();
float t1 = dht1.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
float h2 = dht2.readHumidity();
float t2 = dht2.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h1) || isnan(t1)) {
return;
if (isnan(h2) || isnan(t2)) {
return;
Blynk.virtualWrite(V5, h1);
Blynk.virtualWrite(V6, t1);
Blynk.virtualWrite(V7, h2);
Blynk.virtualWrite(V8, t2);
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth);
//Blynk.begin(auth, "blynk-cloud.com", 8442);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8442);
dht1.begin();
dht2.begin();
BLYNK_WRITE(V11) {
if (BTN1 == true) {
else {
BLYNK_WRITE(V12) {
if (BTN2 == true) {
else {
BLYNK_WRITE(V13) {
BTN3 = param.asInt();
if (BTN3 == true) {
else {
BLYNK_WRITE(V14) {
BTN4 = param.asInt();
if (BTN4 == true) {
else {
BLYNK_WRITE(V15) {
BTN5 = param.asInt();
if (BTN5 == true) {
else {
BLYNK_WRITE(V26) {
BTN6 = param.asInt();
if (BTN6 == true) {
else {
Gunner
May 3, 2018, 10:08pm
14
…and he forgot anyhow
@nervimarco Please read the proper way to post code here…
Hey, welcome to Blynk Community.
This is the best place to ask questions, leave feedback and share your ideas.
If this is the first time you hear about Blynk, check out our website www.blynk.cc and come back!
As the community is big (and growing), let’s agree on some basic rules.
Asking for help
Before creating a new topic and asking for help, please check if your question was already answered:
Use forum search function
You may want to check out:
Blynk Documentation
Blynk Wiki
Blynk Exa…
@nervimarco
I compiled your code and it works fine
so you probably have an issue with one of the libraries !
can you send me error list?
Thank you so much for your support …
the error comes out when I insert the line
“mySwitch.enableTransmit (4);”
gives me error “exit status 1 ‘mySwitch’ does not name a type”
I do not understand.
Thank you
ah ah
you put an extra space !
try enableTransmit(4);
Blynk_Coeur:
ah ah
thanks, I’ve already tried …
nothing changes, always a mistake …
Help…
nervimarco:
always a mistake
are you sure you put mySwitch.enableTransmit(4); at the right place?
it must be into the void setup , like this
mySwitch.enableTransmit(4); //<<<<<<<<<<<<<--------------------
