Hi, it appears since I updated to the latest app it’s eating my battery? This is over two different days, it appears that it is keeping the CPU awake almost all the time - has anyone else noticed this?
Confirm. The same was noted by me in 2.18.2 already. Although I was not aware of battery drainage, I’ve noticed, that I had data sent to server when app was closed (minimized). And those should be only sent when app is opened. I need to manually KILL the Blynk App!
This is a new issue, as before it wasn’t there!
My Android is 6.0.1
@omegab@marvin7
Guys, please check new 2.19.1 build, if it would not fix this issue - I will send you logging build to debug this issue on your phones. Thanks
Do you use home screen widgets? If yes, what are their frequency settings?
Do you use app opened with projects that have enabled ‘keep screen always on’ option?
Are you using GPS Stream/Trigger widgets?
Any of this two options could lead to battery drain.
i had to force stop the app, to not to drain my battery completely.
i do not use homescreen widget, nor gps.
i have “keep screen on” on all my projects, but i do not leaved it open too much on the last days, so it shouldn’t be the cause
Hm, in any case, the next release will contain additional fixes for the possibility of such issue, if I’ll have enough time - I’ll prepare a logging build for this issue.
Yes, I think that issue is fixed, 2.19.2 had a workaround, but next release should have a fix, if not - I’ll create with the release a log build and post here a link, just in case it would not be fixed
sometimes, when the phone switches from wifi to mobile data, i receive fake “hardware gone offline” notifications in the app, but i know for sure that the hardware didn’t gone offline.
it is not very big problem and not happening always, just telling.
There will be several fixes to device status notifications too, I’m not sure, but maybe it will fix this fake notifications issue too. Are they in-app notifications, not the push ones?
@BlynkAndroidDev, is this issue device or system version specific? I’m just asking, as I haven’t noticed any increase in energy consumption by Blynk app. The only issue I had looks like being “solved”. Although it seems SOMETIMES app doesn’t disconnects, but it happened maybe twice since 2.19.2 upgrade
