I looked a rond but don`t see my problem in the topic,
So this is my problem i maked a wheaterstation and use blynk for the read out, i use a BME/BMP 280 in the serial monitor i see all the values that are there, but when i use blynk and add V3 for the huminity there is no read out the value is – and stays that way. can someone help me out here.
This is the part from the sketch that is running.
//get and print humidity data
float humidity = bme280.getHumidity();
Serial.print(“Humidity: “);
Serial.print(humidity);
Serial.println(”%”);
Blynk.virtualWrite(3, humidity); // virtual pin 3
This is the readout wirh the serial mon.
[7717] Ready (ping: 5ms).
Temp: 27.14C
Pressure: 1018.83hPa
Altitude: -46.35m
Humidity: 44.00% < — this part will not turn on the blynk app.
Thanx in advance.
Willy
Here by the full code
#include "Seeed_BME280.h"
#include <Wire.h>
BME280 bme280;
char auth[] = "**********";
char ssid[] = "*******";
char pass[] = "*******";
// Blynk.begin(auth, ssid, pass);
Blynk.begin(auth, ssid, pass, IPAddress(192,168,168,205), 8080);
if(!bme280.init()){
Serial.println("Device error!");
//get and print temperatures
float temp = bme280.getTemperature();
Serial.print("Temp: ");
Serial.print(temp);
Serial.println("C");//The unit for Celsius because original arduino don't support speical symbols
Blynk.virtualWrite(0, temp); // virtual pin 0
Blynk.virtualWrite(4, temp); // virtual pin 4
//get and print atmospheric pressure data
float pressure = bme280.getPressure(); // pressure in Pa
float p = pressure/100.0 ; // pressure in hPa
Serial.print("Pressure: ");
Serial.print(p);
Serial.println("hPa");
Blynk.virtualWrite(1, p); // virtual pin 1
//get and print altitude data
float altitude = bme280.calcAltitude(pressure);
Serial.print("Altitude: ");
Serial.print(altitude);
Serial.println("m");
Blynk.virtualWrite(2, altitude); // virtual pin 2
Serial.print("Humidity: ");
Serial.println("%");
ESP.deepSleep(5 * 60 * 1000000); // // deepSleep time is defined in microseconds. Multiply seconds by 1e6
@Willy_Wva I fixed your code formatting… as per the instructions you seem to have missed when creating this topic
Hey, welcome to Blynk Community.
This is the best place to ask questions, leave feedback and share your ideas.
If this is the first time you hear about Blynk, check out our website www.blynk.cc and come back!
As the community is big (and growing), let’s agree on some basic rules.
Asking for help
Before creating a new topic and asking for help, please check if your question was already answered:
Use forum search function
You may want to check out:
Blynk Documentation
Blynk Wiki
Blynk Exa…
Pleas read the void loop() advice a bit more thoroughly, as no one will fix that but you.
IBK
July 6, 2018, 10:16pm
6
This could work in your case with deepSleep:
#include <Wire.h>
BME280 bme280;
if(!bme280.init())
Blynk.connect();
Serial.print(temp);
Serial.print(p);
} //else
I try it out but it still is not working, the temp and altitude and pressure are working fine and with the monitor i can read everything.
The sleeping from the WeMos was the wakeup call before it got send the humidity it was falling in sleep and not send the value from the reading after setting the line for the second time it was send to Blynk (wait or pauze thit not the trick)
I think you need the Blynk.run() in the loop. “All the Blynk Magic happens here…”
