Hi! I just got a couple of Sonoff s20 power switchs and hacked one to upload SonoffBoilerPlate to be able to control it from blynk.
When setting up the blynk config, I typed my auth token, on server “blynk.server.com” and in port 8443 as said in the server configuration, but the device is not connecting to blynk.
The auth token is copied and pasted, and I see the device on my network map, so no wifi problems.
I was searching the terms sonoff blynk and only retrieving 5 and of that 5 only 2 seemed relevant and neither of them discussed their experience flashing and running. I’ll keep looking, I’ve got two to play with after we return and was just trying to make sure I wasn’t going down an untrod path vs. some of the other options. Sonoff’s are pretty interesting and compact but Ewelink is just a horrible app and the way Chinese company’s come and go makes a cautious person hesitate.
I’m just killing time right now waiting for departure, trying not to order anything and staying out of my wife’s hair.
Oh, and BTW, some phone chargers make terrible power supplies for nodemcu. I swapped one yesterday on my temp project and I was getting crazy readings and notifications, swapped back to another and it all smoothed out. I think I had read at some point that some switching supplies really need a battery present for happiness.
to power the sonoff directly from programmer, remove the jumper and solder together the vcc + 3v3 pins, (see photo) (actually, i do not understand how should one use the programmer with the jumper on, because than it is not possible to connect the vcc cable…)
in ide set:
board: generic esp8266 (for sonoff 1 channel and 2 channel), esp8285 (for sonoff 4 channel)
flash mode: DIO
flash size: 1M (64K SPIFFS)
debug port: disabled
debug level: none
reset method: ck
flash frequency: 40MHz
cpu frequency: 80MHz
upload speed: 115200 (more if the cables are good and short)
keep fw button pressed on sonoff
connect programmer to usb
wait a second, release button
upload firmware (any firmware that works on other esp82 boards, should work on sonoff too, respecting the actual pullup / pulldown resistors)
notes:
on the internet, everywhere writes that the programmer can’t supply enough juice to power the whole sonoff board and it needs separate psu while programming. with the above programmer mods i didn’t found this to be an issue. i can flash without external psu even the 4 channel board. if not working, unplug the usb, wait some seconds, firmly press the fw button, insert the usb, and keep pressed the button for 1-2 seconds, then release. double check the settings in ide, jumper wires connection quality (max length 10~20cm!)
on the 4ch sonoff there is the esp8285 mcu used, so take care while setting the ide! also, to use interrupts on all buttons, there is a special case. please read here
Presumably the silkscreen on 4CH V2 is correct, right?
Ignoring that device I assume as long as the USB2TTL has the same pin order of 3V3, TXD, RXD and GND then any one will work, right?
It’s just the ones I have don’t require the power line to be soldered, they have 3V3 at one side and 5V after the GND pin. Also I guess you can just use jumper wires for the 4CH V2 or if your USB2TTL has a different order of pins to the Sonoff / Itead.
Just to chip in here, this could be due to some programmers use regulators that have a max current output of 200mA such as the HT7333
and the peak current of an esp can exceed it. It would be wise to check the regulator and if it is as stated above, soldering a 1000uF cap over 3.3V and GND pins is advisable at least from my own experience
no, i mean that normally, when connecting 2 devices via serial communication:
rx go to the other devices tx and tx to rx. if we follow this ideology, the silk screen on sonoff th10/16 is correct, but on the sonoff 4ch, one should plug the programmer tx cable to the pin labeled tx, and rx cable to pin labeled rx.
also, if you check the physical circuit on the 4 channel, the header pin labeled rx goes to the mcu tx pin and vice versa. they were in a rush when designing the pcb probably…
Most of the times, the current peak comes when trying to connect to wifi, so, when uploading the firmware there is no problem of using a low current capable programmer. Although, I do recommend use a one more capable, to avoid power issues.
@luis_diaz yes it’s a common problem where users think that if you can flash with a USB2TTL then you should be able to run it too. By then they have disconnected tx and rx and can’t understand why their ESP keeps crashing.
Yes, I hace faced that issue a lot in other forums and pages…
By the way, I’d read somewhere that if you have the power outlet connected to a power socket and you try to download the firmware, it will destroy the sonoff.
