Blynk, AccelStepper, Stepper Motor
Im having issues with my code, I’m trying to get my stepper motor to turn forwards and backwards (Left/Right) Depending on the V1 & V2 buttons being pushed. However the code doesn’t seem to be activating
Here is my code
 #include <Stepper.h>;
 #include <AccelStepper.h>
char auth[] = "62b6ba779d0e47d3850d031059bea256";
#define ENABLE       8
AccelStepper stepper1(2, 5); // pin 3 = step, pin 6 = direction
  pinMode(ENABLE, OUTPUT);
  SwSerial.begin(9600);
  Blynk.begin(Serial, auth);
BLYNK_WRITE(V2) // Button Widget writes to Virtual Pin V5
  int rightBtn = param.asInt();
  if(rightBtn == 1) {     // if Button sends 1
right();             // start the function
void right(){
digitalWrite(ENABLE, LOW);
stepper1.setMaxSpeed(2000.0);
stepper1.setAcceleration(500.0);
stepper1.moveTo(1000);
BLYNK_WRITE(V1) // Button Widget writes to Virtual Pin V5
  int leftBtn = param.asInt();
  if(leftBtn == 1) {     // if Button sends 1
left();             // start the function
void left(){
stepper1.moveTo(-1000);
 stepper1.run();
Hmmm… I wonder why?
For Blynk to work, it needs Blynk.run(); in the void loop, and it doesn’t tend to like other stuff in there as well.
Try searching the forum for Stepper Motor and you’ll find a gazillion working examples.
@Casper_Round As recommended in the Welcome Topic that everyone reads first :wink: … Searching and reading is a good thing :stuck_out_tongue_winking_eye:
HINT somewhere in here might be what you are looking for… at least to get you on the right track.
