Hi Blynker, please help
I am doing a project as below:
Reading temperature and humidity.
Control Pump in auto/manual mode on blynk.
Code:
#include <Blynk.h>
#include "DHTesp.h"
#ifdef ESP32
#pragma message(THIS EXAMPLE IS FOR ESP8266 ONLY!)
#error Select ESP8266 board.
#endif
DHTesp dht;
char auth[] = "";
char ssid[] = "";
char pass[] = "";
const int ledPin1 = D1;
const int ledPin2 = D7;
const int btnPin1 = D5;
const int btnPin2 = D6;
void ManualMode();
int ledState1 = LOW;
int ledState2 = LOW;
int btnState1 = HIGH;
int btnState2 = HIGH;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
Blynk.syncVirtual(V2);
Blynk.syncVirtual(V3);
// Alternatively, you could override server state using:
//Blynk.virtualWrite(V2, ledState);
// When App button is pushed - switch the state
BLYNK_WRITE(V2) {
ledState1 = param.asInt();
digitalWrite(ledPin1, ledState1);
BLYNK_WRITE(V3) {
ledState2 = param.asInt();
digitalWrite(ledPin2, ledState2);
void ManualMode()
if (digitalRead(btnPin1) == LOW) {
if (btnState1 != LOW) {
// Toggle LED state
ledState1 = !ledState1;
// Update Button Widget
Blynk.virtualWrite(V2, ledState1);
btnState1 = LOW;
btnState1 = HIGH;
if (digitalRead(btnPin2) == LOW) {
if (btnState2 != LOW) {
// Toggle LED state
ledState2 = !ledState2;
Blynk.virtualWrite(V3, ledState2);
btnState2 = LOW;
btnState2 = HIGH;
Serial.println();
Serial.println("Status\tHumidity (%)\tTemperature (C)\t(F)\tHeatIndex (C)\t(F)");
String thisBoard= ARDUINO_BOARD;
Serial.println(thisBoard);
// Autodetect is not working reliable, don't use the following line
// dht.setup(17);
// use this instead:
dht.setup(D4, DHTesp::DHT11); // Connect DHT sensor to GPIO 17
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(btnPin1, INPUT_PULLUP);
pinMode(btnPin2, INPUT_PULLUP);
delay(dht.getMinimumSamplingPeriod());
float humidity = dht.getHumidity();
float temperature = dht.getTemperature();
Serial.print(dht.getStatusString());
Serial.print("\t");
Serial.print(humidity, 1);
Serial.print("\t\t");
Serial.print(temperature, 1);
Serial.print(dht.toFahrenheit(temperature), 1);
Serial.print(dht.computeHeatIndex(temperature, humidity, false), 1);
Serial.println(dht.computeHeatIndex(dht.toFahrenheit(temperature), humidity, true), 1);
delay(2000);
Blynk.virtualWrite(V5, humidity);
Blynk.virtualWrite(V6, temperature);
Blynk.syncAll();
@IoTcreator please edit your post (using the pencil icon at the bottom) and add triple backticks at the beginning and end of your code so that it displays correctly.
Mr. Pete, thanks so much! please advise me about how I can create auto/manual mode, also SelectMode.
I would start by reading this, as your current code breaks every Blynk rule in the book:
Once youâve trestructured your code and have it working correctly then Iâd suggest that you re-post your updated code (correctly formatted this time) along with a detailed description of exactly what it is that youâre trying to achieve and what youâve tried already.
As I said, we look forward to seeing your revised code and detailed description of exactly what it is you are trying to achieve.
Dear Mr.Pete,
I tried to code this, but it not working,
âtemperatureâ was not declared in this scope
#include <Blynk.h>
#include "DHTesp.h"
#ifdef ESP32
#endif
DHTesp dht;
char auth[] = "";
char ssid[] = "";
char pass[] = "";
void ManualMode();
BLYNK_CONNECTED() {
BLYNK_WRITE(V2) {
BLYNK_WRITE(V3) {
void ManualMode()
// Toggle LED state
btnState1 = LOW;
btnState1 = HIGH;
// Toggle LED state
btnState2 = LOW;
btnState2 = HIGH;
Serial.println();
// dht.setup(17);
void AutoMode();
int settemp = 30;
void AutoMode()
{if (temperature>setemp){
btnState1 = LOW;
btnState1 = HIGH;
Serial.print("\t");
delay(2000);
Blynk.syncAll();
Henry.
Iâve given you some advice, which youâve chosen not to follow, so Iâll take a step back and see if any other forum members want to step in and try to convince you that your void loop is the first thing you need to tackle.
Sorry, I am a new member.
if have any problem, please advise me!
thanks so much!
I suggest start by doing as Pete says and read the best practices documentation.
It looks like you have declared timer but I donât see any timers in your code. If you want something to happen every so many milliseconds you should be doing that using timers. You need to get rid of all calls to delay in âLoop()â. That would be a good start.
You also shouldnât need to do a Blynk.syncAll() in your loop. Typically a sync is only done after the device first connects to Blynk. For example inside of BLYNK_CONNECTED function.
khoih
February 13, 2020, 7:42pm
11
You can also have a look at this similar project
Iâve seen many people are still interested in DeepSleep.
Just put the SmartFarm_DeepSleep project onto GitHub. The DeepSleep code has been tested several months and very reliable.
The water pump is controlled by the soil moist, measured either by preferably capacitive or resistive moist sensor.
Please note that the MaxDeepSleep Time in ESP8266 is very short, around 220 minutes or less. This features has been automatically taken care and adjusted in the code.
The new features are as folows: âŚ
Thanks so much! I will rework step by step it. I hope that could find whatâs wrong and how can I fix the problem.
thanks All
