@PeteKnight hi,
I switched from Blynk to Blynk IOT, but I can’t receive data even though I appear online in the app.
#define BLYNK_TEMPLATE_ID "**"
#define BLYNK_DEVICE_NAME "Quickstart Device"
#define BLYNK_AUTH_TOKEN "*******"
#include <Ethernet.h>
#define W5100_CS 10
#define SDCARD_CS 4
WidgetLCD lcd(V1);
float VOLTAGE = 0;
float TEMPERATURE = 0;
float SET_TEMP = 0;
int INCOMING_DATA = 0;
#define RELAY 9
const int LM35 = A0;
int UpdateFrequency = 5000L;
int Hysteresis = 1;
//WidgetLED led1(V9);
bool result = Blynk.connected();
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
pinMode (RELAY,OUTPUT);
digitalWrite(RELAY,LOW);
delay(100);
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth);
//Blynk.begin(auth, "blynk.cloud", 80);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8080);
BLYNK_WRITE(V5)
SET_TEMP = param.asInt();
Blynk.virtualWrite(V5,SET_TEMP);
BLYNK_WRITE(V10)
int pinValue = param.asInt();
void sendUpTEMPERATURE()
Blynk.virtualWrite(V5, TEMPERATURE);
INCOMING_DATA = analogRead(LM35);
VOLTAGE = (INCOMING_DATA / 1023.0) * 5000;
TEMPERATURE = VOLTAGE / 10.0;
lcd.print(0, 1, TEMPERATURE);
// to avoid delay() function!
