Are you using virtual or digital pins?
Hi Pete,
I am back at it … no luck.
I am using digital pins.
Regards
I’d always recommend using virtual pins.
OK, I am a novice so was trying to keep it simple. I will have to read up on how to do that unless you have an explanation handy ?
You can try a simple sketch to test your device.
Here’s one I prepared earlier…
Hi John,
That is what i did using the examples in the Arduino.
I got the Arduino to work using the PC, the next was using Blynk and again used the examples to achieve that. the Blynk app sees the Arduino but I cannot control the outputs selected.
Your using blynk legacy right ?
Blynk Version 2.27.30
Okay are you sure you’re using the right auth token ?
Yes Sir, I refreshed that in one of my attempts …
If the auth token is right, then I guess you’re not choosing the right board.
Let’s move step by step.
Board: “Arduino Uno WiFi Rev2, ATMEGA328” right ?
I would like you to try something, go to boards then Arduino AVR boards and choose Arduino uno wifi.
Did you try the avr boards arduino uno wifi ?
To tel the truth I cannot remember - I have not been adventurous in the fear of bending something !
Okay buddy. Let’s start from the beginning step by step.
First the app section, go and update the app to the latest version which is 2.27.32
Second the wiring section, make sure the led is not damaged and connected the right way positive to pin and negative to ground.
Third the Arduino ide section, choose Arduino uno wifi rev2 and use this example :
Follow us: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example shows how to use Arduino MKR 1010
to connect your project to Blynk.
Note: This requires WiFiNINA library
from http://librarymanager/all#WiFiNINA
Feel free to apply it to any other example. It's simple!
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID "YourTemplateID"
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
char pass[] = "YourPassword";
