Hello , IM Using Arduino Mega 2560 and ethernetshield w5100 ,
i used blynk to connect them over internet ( Im new here) my trouble is everytime i try to connect them i get that error in serial monitor ([0] Getting IP… [60731] DHCP Failed!)
The code im using is as following:
This example shows how value can be pushed from Arduino to
the Blynk App.
NOTE:
BlynkTimer provides SimpleTimer functionality:
http://playground.arduino.cc/Code/SimpleTimer
App project setup:
Value Display widget attached to Virtual Pin V5
#include <Ethernet.h>
char auth[] = "hGZtKPzpd1mXylysOrUTtSxLPTG_gR_K";
#define W5100_CS 10
#define SDCARD_CS 4
void myTimerEvent()
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth);
/* You can also specify server:
Blynk.begin(auth, "blynk-cloud.com", 80);
Blynk.begin(auth, IPAddress(192,168,1,100), 8080);
// Setup a function to be called every second*/
Please edit your post to add triple backticks at the beginning and end of your code so that it displays correctly.
Arduino Ethernet shields can be very temperamental. Sometimes they will only work when plugged directly into the router, other times only when plugged into a switch. Sometimes they won’t work at all!
You could try this sketch, and provide all the connection details including an IP address for the shield, your Gateway and DNS server details etc.
I persisted with Ethernet shields for a while before eventually seeing the light and choosing better hardware…
It compiles fine for me.
The Arduino IDE (version 1.8.10) says:
Sketch uses 18230 bytes (7%) of program storage space. Maximum is 253952 bytes.
Global variables use 552 bytes (6%) of dynamic memory, leaving 7640 bytes for local variables. Maximum is 8192 bytes.
Try restarting you PC. If that doesn’t work then it’s probably an issue with your IDE installation.
