Hi, I am currently trying to connect my Arduino Mega to Blynk server using ESP8266 WiFi Shield that I stacked directly on my Arduino Mega. However, when I uploaded my coding, the serial monitor shows error Fail2Rst and FailW as shown below.
Here is my coding. I didn’t know what is wrong with the coding, I used the same coding and same WiFi shield on Arduino UNO, and its working but not with MEGA.
#include <ESP8266_Lib.h>
char auth[] = "KWZCWLkZKfUuJZgy-LM6C5WlLjSgL3";
char ssid[] = "nisheshime";
char pass[] = "aiz1234";
#define EspSerial Serial1
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 38400
ESP8266 wifi(&EspSerial);
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
// to avoid delay() function!
Change my Baud rate but still get the same error. Is it because of the board connection at the serial? Because when I used Arduino UNO, it work perfectly, but not with MEGA. Still confused why I am getting this Fail2Rst error message.
@Izzat_Azman please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
I am using ESP8266 Wi-Fi Shield which is this one. Since it has all the pins aligned to Arduino Mega, I just stacked the WiFi shield on top of Mega. Tried it with UNO with same coding and it works but not with MEGA. I wonder if it’s actually the Mega serial connection?
From the image, it looks like it has an UNO form factor, and that there are no pins to engage with the 14-21 pins in the bottom right hand corner of the Mega board. If this is the case, then there are no pins to engage with the headers for pins 18 and 19, which are the Serial1 connections you are trying to use in your code.
That could work… remove the selection jumpers (on the shield) and use two F-M jumper wires from the respective RX/TX side of the pin rows on the board… IF there is such pins Hard to tell from images alone, to the RX/TX Serial1 pins on the Mega
EDIT… based on the Rev. 2 schematic, there is no user direct pin to the ESP32 RX/TX… However, those do go through a level shifter chip, then to the respective jumper pins. So then you should be able to go from one of them to the appropriate Mega RX/TX pins.
NOTE - I am not sure how this shield handled the needed crossover between devices (ESP32 RX to Mega TX and vice versa)… but if in your testing it doesn’t work, simply swap the wires on one or the other (shield or Mega).
